L2TPv3 for layer 2 over the WAN
Patrick McHenry
Level 4
Level 4
I've labed l2TPv2 over a WAN connection and it seems to work fine. So far I have only configured one VLAN to traverse the L2TPv3 tunnel. There are a couple of VLANs that I would like to send across the WAN. Could I configure several L2TPv3 tunnels(VLANS) off 1 interface - like a trunk? That way, I wouldn't need a new interface on the Headend router for every VLAN I wanted to get to another site.
Thank you, Pat.
Lei Tian
Yes, you can have multiple VLANs to one l2tpv3 tunnel.
HTH,
Lei Tian
Lei,
Thanks for getting back. Do you have any example configs? Good docs fo it?
Thank you.
Hi Patrick,
cisco press book 'layer 2 vpn architectures' is a very good book, and has many configuration examples.
You can read the example from google book
http://books.google.com/books?id=yBL6wF0oFIsC&pg=PT26&lpg=PT26&dq=l2tpv3+ethernet+port+to+port&source=bl&ots=LWD-voz9M4&sig=EAFbduLNzDfo09p7Ww48Qgh0r6s&hl=en&sa=X&ei=n20EUpXyEcPA4AOEkYHoDg&ved=0CF0Q6AEwBg#v=onepage&q=l2tpv3%20ethernet%20port%20to%20p...
Seach for 'ethernet port-to-port emulation' - multiple VLANs to one l2tpv3 tunnel
and 'Ethernet VLAN-to-VLAN emulation' - one VLAN to one l2tpv3 tunnel
HTH,
Lei Tian
