DMVPN Spoke Stops passing traffic after inactivity
Timothy Patrick
I  am trying out a solution using an ISR 829 with a cellular connection. This device will be a spoke in a DMVPN setup. It successfully connects with the hub and I  am able to ping the Hubs tunnel address as well as ping between the sites behind the tunnel addresses.
The ISR829 is using a Verizon connection and sits behind a NAT address of 100.108.7.202/32
I  have tried both transport mode and tunnel mode in my IPSEC configuration and both have worked with one showing the N attribute (Transport) and no N attribute with Tunneled.
(Transport)
# Ent Peer NBMA Addr Peer Tunnel Add     State  UpDn Tm     Attrb
      1   xxx.xxx.xxx.xxx      172.16.124.5       UP    00:20:07     DN
DMVPN_POC_HUB#ping 172.16.124.5
Sending 5, 100-byte ICMP Echos to 172.16.124.5, timeout is 2 seconds:
(Tunneled)
     1           100.108.7.202        172.16.124.5      UP     00:00:46 D
After a certain amount of time(as early as a couple of minutes) traffic stops flowing even though the tunnel still shows up and connected.
      1 xxx.xxx.xxx.xxx.      172.16.124.5          UP     00:03:04 DN
Success rate is 0 percent (0/5)
#HUB
interface Tunnel0
description -> DMVPN HUB Tunnel
ip address 172.16.124.1 255.255.255.0
no ip redirects
ip nhrp authentication dmvpnpoc
ip nhrp network-id 10
tunnel source GigabitEthernet0/0/0
tunnel mode gre multipoint
tunnel key 1
tunnel protection ipsec profile IPSEC_PROFILE
end
#SPOKE
interface Tunnel1
description -> Spoke Tunnel
ip address 172.16.124.5 255.255.255.0
no ip redirects
ip mtu 1440
ip nhrp map multicast xxx.xxx.xxx.xxx
ip nhrp map 172.16.124.1 xxx.xxx.xxx
ip nhrp nhs 172.16.124.1
tunnel source Cellular0/0
tunnel key 1
I  have tried issue the Debug Crypto IPSEC and ISAKMP but nothing useful has come from those logs.
Any help on next steps in troubleshooting would be appreciated.
22 Replies 22
how many Spokes behind NAT (same NAT router )???
Just one
The spoke is the ISR 829 Ithe NAT is happening at the cellular level.
CIsco ISR829(Spoke) <-----------> (HUB) Cisco ISR4331
Hello
sh ip protocols
sh ip route
sh ip nhrp
try the following:
interface Tunnel x
ip mtu 1400
ip tcp adjust-mss 1360
Kind Regards
Paul
IR800#show ip protocols
*** IP Routing is NSF aware ***
Routing Protocol is "application"
  Sending updates every 0 seconds
  Invalid after 0 seconds, hold down 0, flushed after 0
  Outgoing update filter list for all interfaces is not set
  Incoming update filter list for all interfaces is not set
  Maximum path: 32
  Routing for Networks:
  Routing Information Sources:
    Gateway         Distance      Last Update
  Distance: (default is 4)
Routing Protocol is "nhrp"
  Maximum path: 32
  Distance: (default is 250)
IR800#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S*    0.0.0.0/0 is directly connected, Cellular0/0
      10.0.0.0/32 is subnetted, 1 subnets
C        10.1.1.1 is directly connected, wlan-ap0
      100.0.0.0/32 is subnetted, 1 subnets
C        100.93.34.92 is directly connected, Cellular0/0
      172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.16.124.0/24 is directly connected, Tunnel1
L        172.16.124.5/32 is directly connected, Tunnel1
      172.30.0.0/32 is subnetted, 1 subnets
S        172.30.36.210 is directly connected, Tunnel1
      192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/24 is directly connected, Vlan1
L        192.168.1.1/32 is directly connected, Vlan1
      192.168.2.0/32 is subnetted, 1 subnets
C        192.168.2.1 is directly connected, Loopback100
IR800# show ip nhr
IR800# show ip nhrp
172.16.124.1/32 via 172.16.124.1
   Tunnel1 created 00:13:43, never expire
   Type: static, Flags: used
   NBMA address: xxx.xxx.xxx.xxx
--> DMVPN Spoke Stops passing traffic after inactivity
I have read through the post, but I am not really clear on what the problem actually is. Do you want the Cellular to be up all the time ?
If so, try and configure NTP (which permanently tries to synchronize and hence sends out interesting traffic). Also, you could set the 'dialer idle-timeout 0' if your router uses a dialer interface...
The cellular interface does not go down. I  maintain connectivity to the internet at all times. My problem is when I  establish a tunnel to my hub I  am able to pass traffic across that tunnel to the other side with no issues and the other side can reach the spoke. After a few minutes something happens and I  am no longer able to ping or reach anything across the tunnel from either side
Hello
Do you lose connectivity without IPSEC if not then it has to relate with the encryption.
Can you post the output this debug please
debug dmvpn all all
Kind Regards
Paul
First thanks for sharing and help us to detect the issue,
let start troubleshooting
IR800(Spoke)-NAT-Hub
IR800#show ip nhrp traffic
Tunnel1: Max-send limit:10000Pkts/10Sec, Usage:0%
   Sent: Total 197
         1 Resolution Request  0 Resolution Reply  196 Registration Request
         0 Registration Reply  0 Purge Request  0 Purge Reply
         0 Error Indication  0 Traffic Indication  0 Redirect Suppress
   Rcvd: Total 55
         0 Resolution Request  1 Resolution Reply  0 Registration Request
         54 Registration Reply  0 Purge Request  0 Purge Reply
IKEv1 SA: local 100.93.34.92/4500 remote 216.185.188.10/4500 Active
Capabilities:N connid:1207 lifetime:00:29:44
Session ID: 0
IKEv1 SA: local 100.93.34.92/4500 remote 216.185.188.10/4500 Inactive
Capabilities:N connid:1206 lifetime:0
Crypto Session Status: UP-ACTIVE
fvrf: (none), Phase1_id216.185.188.10
IPSEC FLOW: permit 47 host 100.93.34.92 host xxx.xxx.xxx.xxx
Active SAs: 2, origin: crypto map
Inbound: #pkts dec'ed 8 drop 0 life (KB/Sec) 4169134/3585
Outbound: #pkts enc'ed 8 drop 0 life (KB/Sec) 4169134/3585
so according to above
Spoke send registration request and get reply,
and in IPSec there is no drop.
so every think from my view is OK.
then suddenly the traffic drop (no ping)
the issue come from
The Cellular change it IP !!
Yes if the Cellular change it IP then the source address of packet is change
how we can know that
show ip nhrp <<- in Hub
there are two IP
A-NBMA Address
B- claimed Address  <<- claimed address is pre-NAT address (before NAT to NBMA)
if the cellular IP and claimed Address is not match then this issue !!
why ?
the Spoke can send new ISAKMP packet to Hub, here Hub refuse the new ISAKMP new SA because it already have one and it lifetime not end.
here the packet start to drop
how we know that Spoke ask new ISAKMP
show crypto ISAKMP sa
see if there is any delete and new ISAKMP entry add to table
How we can solve this issue
as mention before
1- non-Unique command
2- crypto isakmp keepalive <small interval> periodic
3- if-state nhrp <<- spoke send periodic NHRP message to hub
hope this solve your issue
and one more think
add command
crypto isakmp NAT keepalive <<- this also can add to protect tunnel from timeout of PAT
