Cisco WLC with Non Cisco Env
hs08
Can Cisco WLC work if all switch (core, distribution and layer) not using cisco devices?
 - It will work , the foreign  switch is not an issue , for controller and access point compatibility info's check : https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html , also look into https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
 M.
5 Replies 5
yes. cisco WLC supports with Cisco APs. underlayer network device brand is not an issue.
Good luck
KB
Hi..
i mean AP still using Cisco but switch which connected to AP and core switch which connected to the WLC is non cisco devices. Still the WLC and AP can work normally?
which AP/WLC and non-Cisco switch models are in your network ?
example WLC 5508 and CAP3802, and for switch we use from HP.
 M.
