DMVPN spoke to spoke communication using Certificate based authentication.
PurpleNoc
So running into an issue with my DMVPN deployment.
I have a 4 router lab setup with one hub and 3 spokes.  Hub is setup with nhrp shortcut and redirect.  This feature work flawlessly with simple isakmp using a psk.
Spoke to Spoke communication establishes and they talk to each other without any issues.
So in the interest of better security I have been asked to deploy this setup using certificates for authentication.
Here is where the problem begins.  I can setup the hub as a ca all well and good.  The spokes get their setup as well.  All tunnels come and and my routing protocol establishes as expected, but when i try to icmp from router 2 to router 3 traffic doesn't move between the routers is hairpins all traffic to the hub.  I see two spoke try to bring up tunnels between themselves, but because i am using cert bases isakmp it is not completing.
Is this a drawback of using cert based dmvpn?
Hub Config
crypto pki trustpoint tp-dmvpn
enrollment url http://15.0.0.1:80
revocation-check none
rsakeypair dmvpn
crypto pki certificate chain dmvpn-ca
certificate ca 01
quit
certificate ca rollover 02
quit
crypto pki certificate chain tp-dmvpn
certificate 04
quit
certificate ca 01
quit
crypto isakmp policy 1
encr aes 192
group 2
crypto ipsec transform-set TRANSFORM_SET esp-aes 192 esp-sha-hmac
mode transport
crypto ipsec profile DMVPN_CERT
set transform-set TRANSFORM_SET
interface Loopback0
description Loopback
ip address 1.1.1.1 255.255.255.255
interface Tunnel0
ip address 172.16.0.1 255.255.255.0
no ip redirects
ip mtu 1400
no ip next-hop-self eigrp 777
no ip split-horizon eigrp 777
ip nhrp authentication cisco123
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip nhrp shortcut
ip nhrp redirect
ip tcp adjust-mss 1360
tunnel source GigabitEthernet0/1
tunnel mode gre multipoint
tunnel key 6783
tunnel protection ipsec profile DMVPN_CERT
Spoke Config
rsakeypair dmpvn-cert
certificate 03
quit
certificate ca 01
quit
crypto isakmp policy 2
encr aes 192
group 2
mode transport
interface Loopback0
ip address 3.3.3.3 255.255.255.255
interface Tunnel0
ip address 172.16.0.3 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map 172.16.0.1 15.0.0.1
ip nhrp map multicast 15.0.0.1
ip nhrp nhs 172.16.0.1
ip nhrp shortcut
tunnel key 6783
Thanks Rob
Rob,
just for clarification: only ICMP traffic from router2 (spoke) to router3 (spoke) is not working ? ICMP from hub to spoke and all other traffic is working ?
Can you post the output of 'debug dmvpn all all' ?
All
Was able to figure things out.
The initial problem from spoke to spoke communication after a redirect from the Hub.  Because the two spokes could not authenticate the certs on their respective routers they could not establish a phase one.
So while traffic was not broken it hairpinned to the hub instead of creating a link between the two spokes.
I fixed this by moving the CA off the HUB and off to an independent CA server and had each router request a cert from the CA.  This is allowing the spokes to authenticate with each other and exchange information directly instead of using that hub as a go between.
Rob
Hi Rob,
We are trying to migrate our DMVPN fro PSK to Certificate based authentication. And we are having our own internal CA server. Could you please send me the steps and configuration template to migrate from PSK to Certificate .
1.) Steps to be performed in Microsoft CA server
2.) Steps to be performed in Hub router
3.) Steps to be performed in Spoke router
Thanks in Advance.
Giuseppe Larosa
post complete configurations as attachment files and debug output in separate attachment files and add them to the thread.
You say that traffic is going spoke2 -to - hub - to -spoke3 and viceversa for a failure in setting up the dynamic tunnel between spoke2 and spoke3.
Can you add to the thread the logs from spoke2 and spoke3?
You need to provide more information in order to get better help.
DMVPN using certificates are supported so there is something wrong to be discovered.
Hope to help
Giuseppe
