DMVPN - Tunnel bandwidth recieve / transmit
Samer Abuseini
I have multiple nodes (routers ) connected through DMVPN  with my two DC's , most of the sites complaining about the speed and slowness of the data flow  with other nodes , here is one of the DC config :
interface Tunnel0
 description (VPN-CON)
 bandwidth 200000
 ip address 192.168.0.201 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip wccp 62 redirect in
 no ip next-hop-self eigrp 5
 ip flow ingress
 ip nhrp authentication VPN
 ip nhrp map multicast dynamic
 ip nhrp map 192.168.0.1 PUBLIC IP
 ip nhrp map multicast PUBLIC IP
 ip nhrp map 192.168.0.250 PUBLIC IP
 ip nhrp network-id 100000
 ip nhrp holdtime 600
 ip nhrp nhs 192.168.0.250
 ip nhrp nhs 192.168.0.1
 ip nhrp registration no-unique
 ip tcp adjust-mss 1360
 no ip split-horizon eigrp 5
 load-interval 30
 delay 1500
 qos pre-classify
 tunnel source GigabitEthernet0/0.211
 tunnel mode gre multipoint
 tunnel key 100000
 tunnel protection ipsec profile SDM_Profile1
end
on   sh  int tun0 :
 Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
looks like the default value for recieving and transmitting is 8mb , if i increase the value would it affect the data flow BW on tunnel interface ? and what about the bandwidth 200000 in my tunnel interface config ?
6 Replies 6
Mark Malone
the tunnel bandwidth should be the speed of the wan link , so if its 10mb bandwidth 10000 , is yours 25 ?
config looks right
is the wan link itself slow , is there latency , is the physical interface clean of errors ?
Thanks for your response .
My WAN link is 70mb , my tun0 interface is configured with bandwidth 200mb as shown in config , no errors on physical interface :
sh int gigabitEthernet 0/0
GigabitEthernet0/0 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is 503d.e562.0bd8 (bia 503d.e562.0bd8)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Full Duplex, 1Gbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/0/249 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 4453000 bits/sec, 898 packets/sec
  5 minute output rate 3421000 bits/sec, 877 packets/sec
     3146941362 packets input, 376564804 bytes, 28 no buffer
     Received 6508 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 1 throttles
     0 input errors, 0 CRC, 0 frame, 1152630 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     1884745 packets output, 760996660 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Any more suggestions ?
Thanks in advance
can you elaborate on what 'slow' traffic means in your case ? Which traffic is slow ? How many spokes do you have, and do they al have 70MB links ? Also, since you are using the qos pre-classify command on the tunnel, what traffic is being marked and how, coming into the router ?
hi
slowness : for example i have a node in another geographical location that is connected to my dc (server farm) in Head quarter using DMVPN tunnel requesting instances on ERP system , and almost most of the time the speed rate is 8 kbps , note that the WAN speed on both sides aren't identical , on one of them is 70 m and the other is 15m .  i saw the  overrun on the physical WAN interface on my router is huge , i am not quite sure what this leads to ?
i copied my policy-map config :
Nuqul_Secondary_RTR#sh policy-map
  Policy Map QOS_Dubai_pol
    Class QOS_Dubai_cm
      priority 1024 (kbps)
     police cir 14000000 bc 437500
       conform-action transmit
       exceed-action drop
  Policy Map QOS_Morocco_pol
    Class QOS_Morocco
      bandwidth 1024 (kbps)
  Policy Map h323-policy
    Class h323
      set dscp ef
    Class VOip_map
     police cir 1000000 bc 31250
       exceed-action drop
Nuqul_Secondary_RTR#sh class-map
 Class Map match-any QOS_Dubai_cm (id 1)
   Match access-group name QOS_Dubai
 Class Map match-all VOip_map (id 2)
   Match access-group name voip
   Match protocol rtp
 Class Map match-any class-default (id 0)
   Match any
 Class Map match-any QOS_Morocco (id 3)
   Match access-group name Morocco
 Class Map match-any h323 (id 4)
   Match protocol sip
   Match protocol h323
#sh access-lists
Extended IP access list Morocco
    10 permit ip any host 41.143.255.36
Extended IP access list QOS_Dubai
    10 permit ip any host 213.42.65.186
    20 permit ip any 10.20.0.0 0.0.255.255
Extended IP access list voip
    10 permit udp 10.200.0.0 0.0.255.255 10.100.0.0 0.0.255.255 (218989697 matches)
    20 permit udp 10.1.0.0 0.0.255.255 10.100.0.0 0.0.255.255 (399248081 matches)
Huge amount of overruns are they incrmenting ?
no buffers too only few though
Port looks to be struggling with traffic coming into the buffer , too much too quick could ave a knock on effect for traffic as its being retransmitted when buffer is fulll
Overruns appear in the output of the show interface command when the receiver hardware is unable to hand received data to a hardware buffer because the input rate exceeds the receiver's ability to handle the data.
k.alexey3601
Hi.
Just from privious post:
Tunnel bandwidth transmit and tunnel bandwidth receive are only used with RBSCP - rate based satellite control protocol. "
