Hello need help for final exam
thatguyemy
I am very shy to ask this but i have to pass this test otherwise my life will be over :
I need to do simple static routing network with 3 routers 1 server and couple of pc's
i got confused in packet tracer so i decided to get help here
please i dont need that moral lectures
i undestand that and you gotta understand me too
if you have free time and motivation to do kind work for a guy who's  need help please to it(exam is in 7 hours)
this is ip table
14 Replies 14
post the Packet Tracer project file (.pkt). ZIP it first, otherwise the system won't let you post the file...
i am ashamed doing this but no other way.
i am stuck. i uploaded a pkt file into rar.
i hope cisco community will help me getting this complete mess done
no problem, we are here to help.
Where is the attachment ?
just attached to the previous reply
What are the passwords ?
I was about to replied that
for central its 22232425
I made some changes to your network, PC0 can ping PC7.
What is supposed to be the DHCP server ? You can either use the router or the server on the right top corner...
I was supposed to gave ip adresses from router with dhcp to pc4 pc 5 an pc 6
I have configured the CENTRAL router as DHCP server...
Which version of packet tracer do you have?
i can't open in 7.2 :(
I am using version 7.2.1.0218.
If you cannot open it, I can send you the configs manually...
I am on exam right now and file did not opened. lector gave me a time to manage on pc in auditory if you have a time to do that please send
here are the configs:
R1#sh run
Building configuration...
Current configuration : 1181 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R1
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524KDRS-
spanning-tree mode pvst
interface GigabitEthernet0/0
ip address 192.168.5.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.6.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0
ip address 172.16.0.1 255.255.255.252
interface Serial0/0/1
no ip address
clock rate 2000000
shutdown
interface FastEthernet0/1/0
switchport mode access
switchport nonegotiate
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Vlan1
no ip address
shutdown
router rip
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.0.2
ip flow-export version 9
banner motd ^C
Hello BTU Network
^C
line con 0
line aux 0
line vty 0 4
password Class10
login
end
CENTRAL#sh run
Current configuration : 1701 bytes
version 15.1
hostname CENTRAL
ip dhcp excluded-address 192.168.70.1
ip dhcp excluded-address 192.168.80.1
ip dhcp excluded-address 192.168.80.2
ip dhcp excluded-address 192.168.80.6
ip dhcp excluded-address 192.168.80.20
ip dhcp pool VLAN70
network 192.168.70.0 255.255.255.0
default-router 192.168.70.1
ip dhcp pool VLAN80
network 192.168.80.0 255.255.255.0
default-router 192.168.80.1
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524UCPI-
ip address 192.168.70.1 255.255.255.0
duplex auto
speed auto
ip address 192.168.80.1 255.255.255.0
duplex auto
speed auto
ip address 172.16.0.2 255.255.0.0
clock rate 2000000
ip address 210.165.201.2 255.255.255.252
interface Vlan1
no ip address
shutdown
router rip
ip classless
ip route 192.168.5.0 255.255.255.0 172.16.0.1
ip route 192.168.6.0 255.255.255.0 172.16.0.1
ip route 210.165.202.128 255.255.255.252 210.165.201.1
banner motd ^C
Hello BTU Network
^C
line con 0
password 22232425
login
line aux 0
line vty 0 4
password Class10
login
end
ISP#sh run
Current configuration : 876 bytes
version 15.1
hostname ISP
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524UW5S-
ip address 210.165.202.129 255.255.255.252
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip address 210.165.201.1 255.255.255.252
clock rate 2000000
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 210.165.201.2
line con 0
password pass1234
login
line aux 0
line 0/1/0 0/1/7
login
line vty 0 4
login
end
SW3#sh run
Current configuration : 1329 bytes
version 12.2
hostname SW3
switchport access vlan 80
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 70
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
SW4#sh run
Current configuration : 1179 bytes
version 12.2
hostname SW4
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
I can help you with this, no need to shy  as everyone in this forum has started the career with same doubts.
If you still have this problem just call me directly I can explain it to you easily +91-9790901210 - You can also do a whatsapp call.
Language - English
Please do not hesitate to click the STAR button if you are satisfied with my answer.
