12-08-2020 10:03 PM
we have situation in one of spoke site, it face packet drop with dmvpn hub under bgp, but no drop to hub physical interface. to me, the physical link is fine as no drop to hub physical interface. Can anyone help understand what cause packet drop in the tunnel ?
12-09-2020 12:02 AM
- Check this thread for hints :
https://community.cisco.com/t5/vpn/packet-loss-via-dmvpn-tunnel-but-not-across-wan/td-p/1683925
M.
12-09-2020 12:03 AM
hard to tell, can you post the tunnel config ? Make sure the mtu is set to 1400 (ip mtu 1400) and the 'ip tcp adjust-mss 1360' value is set on your tunnel.
Configuring 'ip tcp mtu-path-discovery' on the tunnel may help as well.
12-09-2020 07:18 AM
Do I understand, correctly, between a hub and a spoke, you "see" drops when using DMVPN but none when not?
If so, please explain "where" you see the "drops" and how you compare DMVPN between hub and spoke vs. when not using DMVPN? (Reason for the last question, often outside of DMVPN, you might do ping tests between hub and spoke, while within a tunnel, besides doing ping tests, tunnel might be carrying traffic.)
It may be help if you would further describe both the physical and logical components.
12-10-2020 09:12 PM
Hi Joseph, when we do lan to lan ping test between hub and spoke, the packet drop occurred, when do ping the WAN interface, no drop. However, we found out the packet drop happened in one of hop on the path. This is quite interested that no drop between end to end interface ping, but drop in one of hop. Now, we swing the traffic to another hub as workaround, no more packet drop in the tunnel.
twkhsxr01#trace 159.12.192.227 so gi0/0/1
Tracing the route to 159.12.192.227
VRF info: (vrf in name/id, vrf out name/id)
1 122.147.199.161 [AS 65003] 0 msec 0 msec 4 msec
2 220.228.21.157 [AS 65003] 0 msec 0 msec
220.228.21.153 [AS 65003] 4 msec
3 220.228.23.141 [AS 65003] 8 msec
220.228.23.145 [AS 65003] 8 msec 8 msec
4 192.72.107.129 [AS 65003] 8 msec
192.72.107.97 [AS 65003] 8 msec
192.72.107.189 [AS 65003] 8 msec
5 139.175.58.145 [AS 65003] 8 msec 8 msec 4 msec
6 192.72.155.150 [AS 65003] 8 msec 8 msec 8 msec
7 192.72.250.10 [AS 65003] 8 msec 8 msec 8 msec not allowed ping after from hop 7
8 103.123.252.133 [AS 65003] 8 msec
103.123.253.133 [AS 65003] 8 msec 8 msec
9 223.26.64.137 [AS 65003] 8 msec 8 msec
223.26.64.141 [AS 65003] 8 msec
10 113.21.95.23 [AS 65003] 12 msec 8 msec 8 msec
11 113.21.84.98 [AS 65003] 8 msec 8 msec 4 msec
12 140.222.4.177 [AS 65003] 64 msec 64 msec 68 msec
13 202.95.64.170 [AS 65003] 68 msec 68 msec 64 msec <<<<<<<<< packet drop in hop 13
14 159.12.192.3 [AS 65003] 68 msec 64 msec 68 msec
end to end no drop
twkhsxr01#ping 159.12.192.227 rep 1000
Sending 1000, 100-byte ICMP Echos to 159.12.192.227, timeout is 2 seconds:
Success rate is 100 percent (1000/1000), round-trip min/avg/max = 56/58/68 ms
twkhsxr01#ping 202.95.64.170 rep 100
Sending 100, 100-byte ICMP Echos to 202.95.64.170, timeout is 2 seconds:
Packet sent with a source address of 10.111.20.1
Success rate is 97 percent (97/100), round-trip min/avg/max = 68/69/72 ms
12-12-2020 01:07 AM
when I ping that IP address with different packet sizes, I get weird results. The last successful ping is with a packet size of 1442, anything bigger is dropped. Does the path to the other hub go through that hop (202.95.64.170) as well ?
C:\Users\pauwe>ping -l 1442 -f 202.95.64.170
Pinging 202.95.64.170 with 1442 bytes of data:
Reply from 202.95.64.170: bytes=1442 time=348ms TTL=240
Reply from 202.95.64.170: bytes=1442 time=345ms TTL=240
Reply from 202.95.64.170: bytes=1442 time=347ms TTL=240
Reply from 202.95.64.170: bytes=1442 time=346ms TTL=240
Ping statistics for 202.95.64.170:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 345ms, Maximum = 348ms, Average = 346ms
C:\Users\pauwe>ping -l 1444 -f 202.95.64.170
Pinging 202.95.64.170 with 1444 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
12-14-2020 01:49 AM
Yes Geroge, this hop is the on the path from other spoke site. However, no packet dorp observed from other site. This is indeed weird.
12-14-2020 06:55 AM - edited 12-14-2020 07:55 AM
Possibly an ISP is having hardware issues or congestion on that one interface, in one direction. I've seen it happen (rarely) before.
Might be worthwhile to reach out to the provider that has that hop and bring this to their attention.
