09-12-2018 04:32 AM - edited 03-05-2019 10:55 AM
DMVPN Tunnel went to NHRP state After Spoke Router Reboot, Once tunnel interface configuration removed and deployed again issue got resolve. this issue happens when spoke router reboot. Kindly suggest on this. Please find below tunnel configuration of Hub and Spoke end.
Spoke End:
interface Tunnel1
ip address 172.16.254.20 255.255.255.0
no ip redirects
ip mtu 1400
ip pim nbma-mode
ip pim sparse-dense-mode
no ip next-hop-self eigrp 50
ip nhrp map 172.16.254.1 X.X.X.X
ip nhrp map multicast X.X.X.X
ip nhrp network-id 101
ip nhrp holdtime 300
ip nhrp nhs 172.16.254.1
ip tcp adjust-mss 1360
delay 12
tunnel source GigabitEthernet0/0/0
tunnel mode gre multipoint
tunnel protection ipsec profile ODMVPN2
Hub End:
interface Tunnel1
bandwidth 200000
ip address 172.16.254.1 255.255.255.0
no ip redirects
ip mtu 1400
ip wccp redirect exclude in
no ip split-horizon eigrp 50
ip pim nbma-mode
ip nhrp map multicast dynamic
delay 120
tunnel source GigabitEthernet0/3.305
end
Debug Logs Before and After Tunnel Interface 1.
Debug Before resetting tunnel 1 interface:
Sep 11 10:59:57.043: NHRP: No SNMP node found to add requestID
Sep 11 10:59:57.043: NHRP: Attempting to send packet through interface Tunnel1 via DEST dst 172.16.254.1
Sep 11 10:59:57.043: NHRP: Send Registration Request via Tunnel1 vrf global(0x0), packet size: 92
Sep 11 10:59:57.044: NHRP-DETAIL: Unable to get dst from pak sb
Sep 11 10:59:57.044: NHRP: Encapsulation succeeded. Sending NHRP Control Packet NBMA Address: X.X.X.X
Sep 11 10:59:57.044: NHRP: 116 bytes out Tunnel1
Sep 11 10:59:57.044: NHRP: Resetting retransmit due to hold-timer for 172.16.254.1
Debug After resetting tunnel 1 interface:
.Sep 11 12:43:56.610: NHRP: Cache already has a subblock node attached for Tunnel Endpoints (VPN: 172.16.254.1, NBMA: X.X.X.X)
.Sep 11 12:43:56.610: NHRP: No SNMP node found to add requestID
.Sep 11 12:43:56.610: NHRP: Attempting to send packet through interface Tunnel1 via DEST dst 172.16.254.1
.Sep 11 12:43:56.610: NHRP: Send Registration Request via Tunnel1 vrf global(0x0), packet size: 92
.Sep 11 12:43:56.611: NHRP-DETAIL: Unable to get dst from pak sb
.Sep 11 12:43:56.611: NHRP-CACHE: Setting 'used' flag on cache entry with nhop: 172.16.254.1
.Sep 11 12:43:56.611: NHRP: Encapsulation succeeded. Sending NHRP Control Packet NBMA Address: X.X.X.X
.Sep 11 12:43:56.611: NHRP: 116 bytes out Tunnel1
.Sep 11 12:43:56.611: NHRP: Resetting retransmit due to hold-timer for 172.16.254.1
.Sep 11 12:43:57.489: NHRP: Setting retrans delay to 2 for nhs dst 172.16.254.1
.Sep 11 12:43:57.489: NHRP: Attempting to send packet through interface Tunnel1 via DEST dst 172.16.254.1
.Sep 11 12:43:57.489: NHRP: Send Registration Request via Tunnel1 vrf global(0x0), packet size: 92
.Sep 11 12:43:57.489: src: 172.16.254.20, dst: 172.16.254.1
.Sep 11 12:43:57.489: NHRP-DETAIL: Unable to get dst from pak sb
.Sep 11 12:43:57.489: NHRP: Encapsulation succeeded. Sending NHRP Control Packet NBMA Address: X.X.X.X
.Sep 11 12:43:57.489: NHRP: 116 bytes out Tunnel1
.Sep 11 12:43:57.490: NHRP-RATE: Sending initial Registration Request for 172.16.254.1, reqid 211
.Sep 11 12:43:58.602: NHRP: Setting retrans delay to 2 for nhs dst 172.16.254.1
.Sep 11 12:43:58.602: IPSEC-IFC MGRE/Tu1(75.99.252.194/X.X.X.X): connection lookup returned 7F36C58B4818
.Sep 11 12:43:58.602: NHRP: Attempting to send packet through interface Tunnel1 via DEST dst 172.16.254.1
.Sep 11 12:43:58.602: NHRP: Send Registration Request via Tunnel1 vrf global(0x0), packet size: 92
.Sep 11 12:43:58.602: src: 172.16.254.20, dst: 172.16.254.1
.Sep 11 12:43:58.603: NHRP-DETAIL: Unable to get dst from pak sb
.Sep 11 12:43:58.603: NHRP: Encapsulation succeeded. Sending NHRP Control Packet NBMA Address: X.X.X.X
.Sep 11 12:43:58.603: NHRP: 116 bytes out Tunnel1
.Sep 11 12:43:58.603: NHRP-RATE: Retransmitting Registration Request for 172.16.254.1, reqid 211, (retrans ivl 2 sec)
.Sep 11 12:43:58.615: NHRP: Receive Registration Reply via Tunnel1 vrf global(0x0), packet size: 112
.Sep 11 12:43:58.615: NHRP-DETAIL: netid_in = 0, t
o_us = 1
.Sep 11 12:43:58.615: NHRP: NHS 172.16.254.1 Tunnel1 vrf 0 Cluster 0 Priority 0 Transitioned to 'RE' from 'E'
.Sep 11 12:43:58.615: NHRP: NHS-UP: 172.16.254.1
09-17-2018 08:16 PM
Hi Georg,
After applying static routes on spoke router i'm unable to ping NHS IP's but DMVPN status is normal. Any suggestion.
Note: I didn't reboot and check whether DMVPN status is moving to NHRP status.
#ping 172.16.254.1
Sending 5, 100-byte ICMP Echos to 172.16.254.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
#ping 10.254.254.1
Sending 5, 100-byte ICMP Echos to 10.254.254.1, timeout is 2 seconds:
#ping 108.58.212.26
Sending 5, 100-byte ICMP Echos to 108.58.212.26, timeout is 2 seconds:
sh dmvpn
Legend: Attrb --> S - Static, D - Dynamic, I - Incomplete
N - NATed, L - Local, X - No Socket
T1 - Route Installed, T2 - Nexthop-override
C - CTS Capable
# Ent --> Number of NHRP entries with same NBMA peer
NHS Status: E --> Expecting Replies, R --> Responding, W --> Waiting
UpDn Time --> Up or Down Time for a Tunnel
Interface: Tunnel1, IPv4 NHRP Details
Type:Spoke, NHRP Peers:2,
# Ent Peer NBMA Addr Peer Tunnel Add State UpDn Tm Attrb
1 69.46.229.182 172.16.254.1 UP 16:03:06 S
1 207.99.106.25 172.16.254.15 UP 15:59:26 D
09-18-2018 01:11 AM
The idea with the static routes was to make sure that EIGRP convergence is not the problem. When you reboot the router WITH the static routes installed, do the tunnels go into up state ?
09-18-2018 03:20 AM
Hi Georg,
Thanks for the response. Please find below logs after applied static route and rebooted the router. DMVPN state went to NHRP state and after reset tunnel interface 1 DMVPN state back to normal. Any other suggestion.
Type:Spoke, NHRP Peers:1,
1 69.46.229.X 172.16.254.1 NHRP 00:00:06 S
OOD-RTR-20-001#sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst src state conn-id status
216.105.104.195 75.99.252.X QM_IDLE 1002 ACTIVE
69.46.229.182 75.99.252.X QM_IDLE 1001 ACTIVE
IPv6 Crypto ISAKMP SA
09-18-2018 05:54 AM
Hi Sathish
Your configuration looks wierd. Following what you posted the simple configuration looks as followed:
HUB Tunnel Config:
interface Tunnel1
!tunnel key 0
end
interface GigabitEthernet0/3.305
encapsulation dot1Q 305
ip address 69.46.229.X 255.255.255.252
ip nat outside
end
Spoke Config:
interface Tunnel0
ip address 10.254.254.20 255.255.255.0
ip nhrp map multicast 108.58.212.26
ip nhrp map 10.254.254.1 108.58.212.26
ip nhrp network-id 100
ip nhrp nhs 10.254.254.1
tunnel key 0
interface GigabitEthernet0/0/0
ip address 75.99.252.X 255.255.255.248
ip nat outside
Theres is no "tunnel key 0" in the hub config and also the nhs server configured on the spoke need to be the IP address of the tunnel interface configured on the hub. This nhs address need to have the nbma address correspond to the source interface of tunnel configured on the hub. But in your configuration the HUB nbma address configured in the hub is 69.46.229.X and the HUB nbma address configured in the spoke is 108.58.212.26
Also the underlay configuration need to be Ok, both nbma addresses need to be reachable form each other.
Could you modify the config ?
09-18-2018 06:01 AM
Sorry for this. I wrongly pasted the tunnel 0 configuration. Spoke end tunnel config is tunnel 1.
Current configuration : 498 bytes
interface Tunnel1
description "DMVPN SPOKE 20 - DMVPN-1"
no ip redirects
ip mtu 1400
ip pim nbma-mode
ip nhrp map 172.16.254.1 69.46.229.X
ip nhrp map multicast 69.46.229.X
delay 120
end
#sh run int GigabitEthernet0/0/0
Building configuration...
Current configuration : 162 bytes
description external to internet (CableVision)
ip nat outside
negotiation auto
end
09-18-2018 06:25 AM - edited 09-18-2018 06:26 AM
Ok that sounds better.
Could you perform these tests from the spoke router.
Before the reboot when the tunnel is UP
show dmvpn
sh ip route 69.46.229.X
sh ip cef 69.46.229.X
ping 69.46.229.X
After the reboot when the tunnel is in NHRP state
show dmvpn
ping 69.46.229.X
After the reboot when you remove the tunnel configuration
ping 69.46.229.X
Also add a tunnel key on both tunnel interfaces.
09-18-2018 06:45 AM
Hi ulrickfr2001
Thanks for the response. Sorry right now production started i unable to do changes on spoke end. I will share you logs once production ended.
many spokes are connected to that hub, if i deploy key on tunnel interface on HUB end it will get impact for other spokes is it?
09-18-2018 08:22 AM
Yes it will. In that case do not add the tunnel key.
09-18-2018 10:30 PM
Hi ulrickfr2001,
Thanks for your response. Please find below logs.
1. Logs when tunnel is up & before reboot:
1 69.46.229.X 172.16.254.1 UP 18:52:27 S
1 207.99.106.X 172.16.254.15 UP 18:48:15 D
OOD-RTR-20-001#sh ip route 69.46.229.X
% Network not in table
OOD-RTR-20-001#sh ip cef 69.46.229.X
69.46.229.X/32
nexthop 75.99.252.X GigabitEthernet0/0/0
OOD-RTR-20-001#
OOD-RTR-20-001#ping 69.46.229.X
Sending 5, 100-byte ICMP Echos to 69.46.229.X, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 9/10/12 ms
OOD-RTR-20-001#
2. logs after spoke reboot & DMVPN is in NHRP state
1 69.46.229.X 172.16.254.1 NHRP 00:00:45 S
OOD-RTR-20-001#
69.46.229.X/32
OOD-RTR-20-001#
Success rate is 100 percent (5/5), round-trip min/avg/max = 9/9/10 ms
OOD-RTR-20-001#
3. logs after spoke reboot & Tunnel 1 reset & DMVPN is in UP.
2 69.46.229.X 172.16.254.1 UP 00:01:52 S
172.16.254.15 UP 00:01:49 D
OOD-RTR-20-001#
69.46.229.X/32
OOD-RTR-20-001#
Success rate is 100 percent (5/5), round-trip min/avg/max = 9/10/13 ms
OOD-RTR-20-001#
09-19-2018 02:46 AM
Looks like everything OK on network ip configuration. Maybe the issue is related to the ipsec.
Could you provide the output of theses commands
1 when the tunnel is up and running
show crypto isa sa
show crypto ipsec sa
2 after the device's reboot and the tunnel is in nhrp state
show crypto isa sa
09-19-2018 03:17 AM
Thanks for the response. Logs captured as you advice. Any suggestion.
Logs before when tunnel is in UP status and before reboot:
#show crypto isa sa
207.99.106.X 75.99.252.X QM_IDLE 1007 ACTIVE
108.58.212.X 75.99.252.X MM_NO_STATE 0 ACTIVE
108.58.212.X 75.99.252.X MM_NO_STATE 0 ACTIVE (deleted)
69.46.229.X 75.99.252.X QM_IDLE 1003 ACTIVE
216.105.104.X 75.99.252.X QM_IDLE 1002 ACTIVE
1#show crypto ipsec sa
interface: Tunnel10
Crypto map tag: Tunnel10-head-0, local addr 75.99.252.X
protected vrf: (none)
local ident (addr/mask/prot/port): (75.99.252.X/255.255.255.255/47/0)
remote ident (addr/mask/prot/port): (216.105.104.X/255.255.255.255/47/0)
current_peer 216.105.104.X port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 75.99.252.X, remote crypto endpt.: 216.105.104.X
plaintext mtu 1438, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0/0
current outbound spi: 0x3E9F13FC(1050612732)
PFS (Y/N): N, DH group: none
inbound esp sas:
spi: 0x8ADC6CB7(2329701559)
transform: esp-256-aes esp-sha-hmac ,
in use settings ={Tunnel, }
conn id: 2027, flow_id: ESG:27, sibling_flags FFFFFFFF80004048, crypto map: Tunnel10-head-0
sa timing: remaining key lifetime (sec): 1562
Kilobyte Volume Rekey has been disabled
IV size: 16 bytes
replay detection support: Y
Status: ACTIVE(ACTIVE)
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 2028, flow_id: ESG:28, sibling_flags FFFFFFFF80004048, crypto map: Tunnel10-head-0
IV size: 16 bytes
outbound ah sas:
outbound pcp sas:
interface: Tunnel0
Crypto map tag: Tunnel0-head-0, local addr 75.99.252.X
remote ident (addr/mask/prot/port): (108.58.212.X/255.255.255.255/47/0)
current_peer 108.58.212.X port 500
PERMIT, flags={origin_is_acl,ipsec_sa_request_sent}
#send errors 1260, #recv errors 0
local crypto endpt.: 75.99.252.X, remote crypto endpt.: 108.58.212.X
plaintext mtu 1400, path mtu 1400, ip mtu 1400, ip mtu idb Tunnel0
current outbound spi: 0x0(0)
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
interface: Tunnel1
Crypto map tag: Tunnel1-head-0, local addr 75.99.252.X
remote ident (addr/mask/prot/port): (207.99.106.X/255.255.255.255/47/0)
current_peer 207.99.106.X port 500
#pkts encaps: 6610, #pkts encrypt: 6610, #pkts digest: 6610
#pkts decaps: 5651, #pkts decrypt: 5651, #pkts verify: 5651
local crypto endpt.: 75.99.252.X, remote crypto endpt.: 207.99.106.X
plaintext mtu 1378, path mtu 1400, ip mtu 1400, ip mtu idb Tunnel1
current outbound spi: 0x645B6C29(1683713065)
inbound esp sas:
spi: 0xFB9D18FF(4221376767)
transform: esp-3des ,
in use settings ={Transport, }
conn id: 2017, flow_id: ESG:17, sibling_flags FFFFFFFF80004008, crypto map: Tunnel1-head-0
sa timing: remaining key lifetime 19 hours, 45 mins
IV size: 8 bytes
replay detection support: N
spi: 0xC88DF61A(3364746778)
conn id: 2019, flow_id: ESG:19, sibling_flags FFFFFFFF80000008, crypto map: Tunnel1-head-0
IV size: 8 bytes
inbound ah sas:
inbound pcp sas:
outbound esp sas:
spi: 0x25A199E2(631347682)
conn id: 2018, flow_id: ESG:18, sibling_flags FFFFFFFF80004008, crypto map: Tunnel1-head-0
IV size: 8 bytes
conn id: 2020, flow_id: ESG:20, sibling_flags FFFFFFFF80000008, crypto map: Tunnel1-head-0
IV size: 8 bytes
outbound ah sas:
outbound pcp sas:
remote ident (addr/mask/prot/port): (69.46.229.X/255.255.255.255/47/0)
current_peer 69.46.229.X port 500
#pkts encaps: 15094, #pkts encrypt: 15094, #pkts digest: 15094
#pkts decaps: 11021, #pkts decrypt: 11021, #pkts verify: 11021
local crypto endpt.: 75.99.252.X, remote crypto endpt.: 69.46.229.X
current outbound spi: 0xD3F6081A(3556116506)
inbound esp sas:
spi: 0x9AB40336(2595488566)
conn id: 2009, flow_id: ESG:9, sibling_flags FFFFFFFF80004008, crypto map: Tunnel1-head-0
sa timing: remaining key lifetime 19 hours, 42 mins
IV size: 8 bytes
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 2010, flow_id: ESG:10, sibling_flags FFFFFFFF80004008, crypto map: Tunnel1-head-0
IV size: 8 bytes
outbound ah sas:
outbound pcp sas:
Logs after spoke reboot and Tunnel is in NHRP status:
1 69.46.229.X 172.16.254.1 NHRP 00:00:05 S
#show crypto isa sa
69.46.229.X 75.99.252.X QM_IDLE 1001 ACTIVE
interface: Tunnel10
current outbound spi: 0x9E69D2EA(2657735402)
inbound esp sas:
spi: 0xB3743BB(188171195)
conn id: 2003, flow_id: ESG:3, sibling_flags FFFFFFFF80004048, crypto map: Tunnel10-head-0
sa timing: remaining key lifetime (sec): 3545
IV size: 16 bytes
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 2004, flow_id: ESG:4, sibling_flags FFFFFFFF80004048, crypto map: Tunnel10-head-0
IV size: 16 bytes
outbound ah sas:
outbound pcp sas:
interface: Tunnel1
#pkts encaps: 17, #pkts encrypt: 17, #pkts digest: 17
#pkts decaps: 30, #pkts decrypt: 30, #pkts verify: 30
current outbound spi: 0x663B3256(1715155542)
inbound esp sas:
spi: 0x7D70493F(2104510783)
conn id: 2001, flow_id: ESG:1, sibling_flags FFFFFFFF80004008, crypto map: Tunnel1-head-0
sa timing: remaining key lifetime 23 hours, 59 mins
IV size: 8 bytes
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 2002, flow_id: ESG:2, sibling_flags FFFFFFFF80004008, crypto map: Tunnel1-head-0
IV size: 8 bytes
outbound ah sas:
outbound pcp sas:
interface: Tunnel0
#send errors 4, #recv errors 0
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
09-19-2018 03:45 AM
Looks like on spoke side everything is OK. The packets are digested and verified in that tunnel before and after the reboot.
Could you confirm the same on the hub side before and after reboot?
09-18-2018 08:55 AM - edited 09-18-2018 08:55 AM
one other thing you could do is configure Interface State Control on the (spoke only) tunnel:
interface Tunnel1
if-state nhrp
09-18-2018 10:47 PM
Hi Georg,
Thanks for your response. I tired below config on tunnel 1 but no luck went to NHRP after spoke reboot. Any other suggestion.
if-state nhrp
1 69.46.229.X 172.16.254.1 NHRP 00:05:06 S
10-02-2018 12:19 PM
did you ever get this resolved? I'm having the same issue.
