Dmvpn
burhaans28
I am doing dmvpn I am unable to ping 10.1.1.2 which is spoke from hub
and i cant't see any route in hub routing table on tunnel interface
and i am doing eigrp on overlay
but i am unable to create eigrp adjacency between hub and spoke
this is my config
Hub
conf ter
hostname Hub
int lo 0
ip add 10.10.10.10 255.255.255.255
exit
int gig 0/0
ip add 100.1.2.1 255.255.255.0
no sh
exit
ip route 0.0.0.0 0.0.0.0 100.1.2.2
int tunnel 1
ip add 10.1.1.1 255.255.255.0
tunnel source gig 0/0
tunnel mode gre multipoint
ip nhrp network-id 1
ip nhrp map 10.1.1.2 101.0.0.2
exit
router eigrp 100
network 10.0.0.0
R2
int lo 0
ip add 100.0.0.3 255.255.255.255
ip ospf 1 area 0
exit
int gig 0/0
ip add 100.1.2.2 255.255.255.0
no sh
exit
int gig 0/1
ip add 100.0.3.1 255.255.255.0
no sh
ip ospf 1 area 0
exit
router ospf 1
router-id 100.0.0.3
exit
router bgp 1
no bgp default ipv4-unicast
neighbor 100.0.0.4 remote-as 1
neighbor 100.0.0.4 update-source Loopback0
address-family ipv4
network 100.0.3.0 mask 255.255.255.0
network 100.1.2.0 mask 255.255.255.0
neighbor 100.0.0.4 activate
exit
exit
ip route 0.0.0.0 0.0.0.0 100.1.2.1
R4
conf ter
int lo 0
ip add 100.0.0.4 255.255.255.255
ip ospf 1 area 0
exit
int gig 0/0
ip add 100.0.3.2 255.255.255.0
no sh
ip ospf 1 area 0
exit
int gig 0/1
ip add 101.0.0.1 255.255.255.0
no sh
exit
router ospf 1
router-id 100.0.0.4
exit
router bgp 1
neighbor 100.0.0.3 remote-as 1
neighbor 100.0.0.3 update-source Loopback0
address-family ipv4
network 101.0.0.0 mask 255.255.255.0
neighbor 100.0.0.3 activate
exit
exit
ip route 101.0.0.0 255.255.255.0 101.0.0.2
Spoke1
conf ter
hostname spoke1
int lo0
ip add 25.25.25.25 255.255.255.255
exit
int gig 0/0
ip add 101.0.0.2 255.255.255.0
no sh
exit
ip route 0.0.0.0 0.0.0.0 101.0.0.1
int tunnel 1
ip add 10.1.1.2 255.255.255.0
tunnel destination 100.1.2.1
ip nhrp map 10.1.1.1 100.1.2.1
exit
router eigrp 100
network 10.0.0.0
5 Accepted Solutions
ponzki
@burhaans28 , looks like you are missing multicast capability config.
Pls configure and add the following on the Hub router and provide results:
int tunnel 1
ip nhrp map multicast 101.0.0.2
Hello
Providing your underlay is all working correctly you need to allow nhrp multicast on the nbma address and disable split horizon
hub
int tunnel 1
no ip split-horizon
Kind Regards
Paul
ponzki
@paul driver - in his topology, disabling split horizon is optional. But yes, if you have other spokes you want to connect to the DMVPN, you would need to disable split horizon.
Yeah Dmvpn is working now Thanks a lot
Yeah its working Thanks a lot
6 Replies 6
ponzki
int tunnel 1
Hello
hub
int tunnel 1
no ip split-horizon
Kind Regards
Paul
Here DMVPN is working fine i can ping from hub to spoke
But from Hub to Vios I am working ospf 1
this is the config
Vios
int gig 0/0
ip add 10.11.3.1
no sh
ip ospf 1 area 0
On hub router
int gig 0/1
ip add 10.11.3.1
no sh
ip ospf 1 area 0
So i can't ping 10.11.3.1 and lo0 1.1.1.1 from spoke
but i can ping 10.11.3.2 which is on Hub router
ponzki
