DMZ Link Bandwidth & bestpath as-path multipath-relax | Clarification
Ibrahim Jamil
Level 6
Level 6
Hi Netpro
so DMZ Link Bandwidth used for unequal-cost load-balancing with peer to same AS on 1 local router
aka R1 connected to 2 upstream ISP whereas 1st Lnik comes with 100Mbps while 2nd Link comes with 50 Mbs
WHILE
bgp bestpath as-path multipath-relax used load balance traffic with 2 AS peer usinf Two local router
aka R1 and R2 each connected to different AS WITH unequal-cost load-balancing . aka R1 Has 1 Gbps pipe while R2 has 500Mpbs pipe
pls Advise
Deepak Kumar
Your question is not clear. Please elaborate.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
