dns lan wan
rammon
Hi ,
I completed my cisco ccna course .i have a confusion how DNS, ip addresses are assigned to host in a branch office .with 150-200 hosts ..i mean is it complusory to use ms servers or configuring dhcp server ,dns server on routers.
Deepak Kumar
You can configure DHCP server on your router also.
Configuration will be like:
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp pool LAN
import all
network 10.10.10.0 255.255.255.0
dns-server 8.8.8.8 8.8.4.4
default-router 10.10.10.1
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak Kumar
ip dhcp pool LAN
import all
Deepak Kumar
Deepak Kumar,
Ok
dued your saying i can configure dhcp server on router also . is it not necessary to use ms server if this configuration is used.
rammon
Yes,  it is not necessary to use ms server if DHCP server configured on the router.
Deepak Kumar
Deepak Kumar,
HI,
Is ms servers are a completely separate environment .is it not at all used in cisco R&s environment.
