DNS on Cisco router with split DNS - avoiding Nat NVI
dastrix80
zHi Team
Ive got a number of hosts on my lan that I need to reference using domain names in applications.
Those applications are used internally and externally, so whilst NAT NVI helps it stuffs up aload of other things on my network so i figure use DNS.
When on the LAN, my hosts cant ping the dns names.
Heres my config, ip domain lookup is on
ip domain name ddns.net
ip host doorbird 192.168.0.141
ip host grafana80 192.168.0.3
ip host oh2 192.168.0.3
ip host dastrix80 192.168.0.3
ip host blueiris 192.168.0.4
ip dns server
In my external DNS server,  I reference the same names (doorbird.ddns.net) with my PUBLIC IP.
Internally though, having my clients set to the router LAN IP as their Primary DNS, I cant ping the names.
C:\Users\Kris>ping doorbird
Ping request could not find host doorbird. Please check the name and try again.
C:\Users\Kris>ping blueiris
Ping request could not find host blueiris. Please check the name and try again.
C:\Users\Kris>
Any thoughts as to why?
LAN interface on my PC
Wireless LAN adapter Wi-Fi:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Intel(R) Centrino(R) Wireless-N 2230
   Physical Address. . . . . . . . . : 60-6C-66-8E-B3-04
   DHCP Enabled. . . . . . . . . . . : No
   Autoconfiguration Enabled . . . . : Yes
   IPv4 Address. . . . . . . . . . . : 192.168.0.10(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . : 192.168.0.254
   DNS Servers . . . . . . . . . . . : 192.168.0.254
                                       202.142.142.142
   NetBIOS over Tcpip. . . . . . . . : Enabled
Router LAN interface
3945-KK#sh run int vlan1
Building configuration...
Current configuration : 190 bytes
interface Vlan1
 description "Link to the 192.168.0.x LAN"
 ip address 192.168.0.254 255.255.255.0
 no ip redirects
 ip nat inside
 ip virtual-reassembly in
 zone-member security LAN
end
Kris
added the domain name onto the hostname and rebooted the router - works.
Go figure! :P
Hello
conf t
ip domain-lookup
Kind Regards
Paul
I had that in there, same issue :(
my full config
Go figure! :P
