DNS resolution on 1841 with static IPs
saurabh_knl
hi,
I need to know that if 1841 or any other cisco router is capable of DNS resolution when provided static IPs on the internal LAN? Its like I dont want to give WAN DNS entries on the desktops on LAN for the DNS resolution. I want to give router's IP as the DNS entry for desktops, and enable router to perform the required DNS resolution.
Kindly advise.
sourabhagarwal
Level 4
Level 4
Yes, it is very much possible to configure router to act as DNS server. you need to define a static host name-to-address mapping in the host name cache of router.
check below URL to get more information.
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804455de.html
Also, if your network have DNS server, it is possible to configure DNS on the router using below command.
Router(config)# ip name-server
check this URL to get more information.
http://www.cisco.com/warp/public/105/reversedns.pdf
hope it helps ... rate if it does ...
