Interface Naming
bfrericks
Sorry for this simple question,
I have a couple 2-pot WIC cards. They showup as serial0/0/0:0. They are in a 2811 router. Two questions:
1. What does each position in the 0/0/0:0 symbolize? I recall that it used to be slot#/port# but that is only two positions.
2. What would the correct setup for channel-groups be for each interface? I am implementing MLPPP for 3 links. Should I configure each port on the 2-port wics and channel group 0 or 0 and 1 respectivly? Basically should they showup as serial0/0/0:0 and serial0/0/0:1 or serial0/0/0:0 and serial0/0/1:0? Basically looking for best practices. I am not channelizing, they will all be using all 24.
Thanks in advnace!
Blake
2 Accepted Solutions
royalblues
Level 11
Level 11
Hi Blake,
The postions indicate module/slot/port number
These were the naming conventiones which were used for routers having VIP cards(slot/port adapter/port) installed and i think cisco has incorporated the same on the ISR routers
Regarding your second question
Whenever you configure a channel group a corredponding interface will be created say for eg. serial0/0/0:0.
The first 3 digits correspond to the Controller port (in above case e1 0/0/0)and the one after the colon is the channel group number.
If you create channel-group 1 the corresponding interface which would be created is serial0/0/0:1
THe Number of channel groups that can be created also varies with the platform and the type of interface card.
Since you will be using all the 24 channels,
the best configuration would be create a single channel group 0 for all the 3 links and bundle.
sample configuration
Controller e1 0/0/0
channel-group 0 timeslots 1-24
Controller e1 0/1/0
Controller e1 0/2/0
interface multilink 1
ip address x.x.x.x y.y.y.y
ppp multilink
ppp multilink group 1
interface serial 0/0/0:0
no ip address
encap ppp
ppp multilink
interface serial 0/1/0:0
no ip address
encap ppp
ppp multilink
interface serial 0/2/0:0
no ip address
encap ppp
ppp multilink
HTH, rate if it does
Narayan
amit-singh
Level 11
Level 11
Blake
1. Serial 0/0/0:0 signifies the module/slot/port number on the 2811 router. Please check the link below for better understanding of the interface naming on ISR routers:
http://www.cisco.com/en/US/products/hw/routers/ps282/products_tech_note09186a008035b051.shtml
2. It really doesnot matter the way interfaces appear in a multiplink configuration. The most important is that you should have the same multilink group configured under all the interfaces.
HTH,Please rate if it does.
-amit singh
royalblues
Level 11
Level 11
Hi Blake,
Controller e1 0/0/0
Controller e1 0/1/0
Controller e1 0/2/0
ppp multilink
no ip address
encap ppp
ppp multilink
no ip address
encap ppp
ppp multilink
no ip address
encap ppp
ppp multilink
Narayan
amit-singh
Level 11
Level 11
Blake
-amit singh
