redistributing inter vrf routes in OSPF
I ma working on a VRF-Lite lab, I craeted 2 VRF instances ( student and staff)
my network topology has 1 core switch and 2 distribution switches, I am using a cisco 9300 switches with IP routing enabled
i have configured configured OSPF fro my routing protocols for each VRF
on the core switch I have configured BGP protocols to redistribute inter VRF route (BGP only on the core) to the OSPF instances
i can see all the routes on the core but on the distribution i only see ospf routes from the same VRF
the routes exist in the ospf database but in the table
need help figuring out why the inter VRF routes are no showing or populating in the VRF routing table
Core#show ip route vrf staff
Routing Table: staff
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 20 subnets, 2 masks
O IA 10.64.11.254/32 [110/3] via 10.196.2.10, 01:52:13, Vlan3002
O IA 10.64.21.254/32 [110/2] via 10.196.2.42, 01:52:17, Vlan3004
B 10.162.11.254/32 [20/3] via 10.196.1.10 (student), 01:52:13, Vlan3001
B 10.162.21.254/32 [20/2] via 10.196.1.42 (student), 01:52:17, Vlan3003
B 10.196.1.0/29 is directly connected, 07:19:37, Loopback1
L 10.196.1.1/32 is directly connected, Loopback1
B 10.196.1.2/32 [20/3] via 10.196.1.10 (student), 01:52:17, Vlan3001
B 10.196.1.3/32 [20/2] via 10.196.1.42 (student), 01:52:17, Vlan3003
B 10.196.1.8/29 is directly connected, 07:19:37, Vlan3001
L 10.196.1.9/32 is directly connected, Vlan3001
B 10.196.1.40/29 is directly connected, 02:40:18, Vlan3003
L 10.196.1.41/32 is directly connected, Vlan3003
C 10.196.2.0/29 is directly connected, Loopback2
L 10.196.2.1/32 is directly connected, Loopback2
O 10.196.2.2/32 [110/3] via 10.196.2.10, 01:52:17, Vlan3002
O 10.196.2.3/32 [110/2] via 10.196.2.42, 01:52:17, Vlan3004
C 10.196.2.8/29 is directly connected, Vlan3002
L 10.196.2.9/32 is directly connected, Vlan3002
C 10.196.2.40/29 is directly connected, Vlan3004
L 10.196.2.41/32 is directly connected, Vlan3004
Core#show ip route vrf student
Routing Table: student
B 10.64.11.254/32 [20/3] via 10.196.2.10 (staff), 01:52:35, Vlan3002
B 10.64.21.254/32 [20/2] via 10.196.2.42 (staff), 01:52:39, Vlan3004
O IA 10.162.11.254/32 [110/3] via 10.196.1.10, 01:52:35, Vlan3001
O IA 10.162.21.254/32 [110/2] via 10.196.1.42, 01:52:39, Vlan3003
C 10.196.1.0/29 is directly connected, Loopback1
O 10.196.1.2/32 [110/3] via 10.196.1.10, 01:52:39, Vlan3001
O 10.196.1.3/32 [110/2] via 10.196.1.42, 01:52:39, Vlan3003
C 10.196.1.8/29 is directly connected, Vlan3001
C 10.196.1.40/29 is directly connected, Vlan3003
B 10.196.2.0/29 is directly connected, 07:19:59, Loopback2
B 10.196.2.2/32 [20/3] via 10.196.2.10 (staff), 01:52:39, Vlan3002
B 10.196.2.3/32 [20/2] via 10.196.2.42 (staff), 01:52:39, Vlan3004
dore config:
B 10.196.2.8/29 is directly connected, 07:19:59, Vlan3002
B 10.196.2.40/29 is directly connected, 02:40:40, Vlan3004
Distr1#show ip route vrf student
10.0.0.0/8 is variably subnetted, 10 subnets, 3 masks
C 10.162.11.0/24 is directly connected, Loopback10
L 10.162.11.254/32 is directly connected, Loopback10
O IA 10.162.21.254/32 [110/3] via 10.196.1.9, 01:52:54, Vlan3001
O 10.196.1.1/32 [110/2] via 10.196.1.9, 01:52:54, Vlan3001
L 10.196.1.2/32 is directly connected, Loopback1
O 10.196.1.3/32 [110/3] via 10.196.1.9, 01:52:54, Vlan3001
L 10.196.1.10/32 is directly connected, Vlan3001
O 10.196.1.40/29 [110/2] via 10.196.1.9, 01:52:54, Vlan3001
Core config:
Core#show run
Building configuration...
Current configuration : 9450 bytes
! Last configuration change at 23:29:05 UTC Wed Aug 14 2019 by test
version 16.6
no service pad
no platform punt-keepalive disable-kernel-core
hostname Core
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
vrf definition staff
rd 800:2
route-target export 800:2
route-target export 800:1
route-target import 800:2
route-target import 800:1
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
vrf definition student
rd 800:1
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
aaa session-id common
switch 1 provision c9300-24p
ip routing
ipv6 unicast-routing
vlan 30
name VRF-Lite-LP30
vlan 100
name ospf100
vlan 101
name ospf101
vlan 3001
name ospf3001StudentVRF
vlan 3002
name ospf3002StaffVRF
vlan 3003
name ospf3003StudentVRF
vlan 3004
name ospf3004StaffVRF
interface Loopback0
ip address 10.196.12.1 255.255.255.248
interface Loopback1
description OSPF router student VRF
vrf forwarding student
ip address 10.196.1.1 255.255.255.248
interface Loopback2
description OSPF router staff VRF
vrf forwarding staff
ip address 10.196.2.1 255.255.255.248
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
ip address 10.194.177.231 255.255.240.0
speed 1000
negotiation auto
interface GigabitEthernet1/0/1
switchport trunk allowed vlan 30
switchport mode trunk
interface GigabitEthernet1/0/23
switchport trunk pruning vlan none
interface GigabitEthernet1/0/24
interface Vlan30
ip address 10.192.32.2 255.255.255.240
interface Vlan100
ip address 10.196.12.9 255.255.255.248
ip ospf network point-to-point
ip ospf 100 area 0
ip ospf cost 2
interface Vlan101
ip address 10.196.12.41 255.255.255.240
ip ospf 100 area 0
interface Vlan3001
description ospf L3 area0
ip address 10.196.1.9 255.255.255.248
ip ospf 101 area 0
ip ospf cost 2
interface Vlan3002
ip address 10.196.2.9 255.255.255.248
ip ospf 102 area 0
ip ospf cost 2
interface Vlan3003
description ospf L3 area0 student VRF
ip address 10.196.1.41 255.255.255.248
interface Vlan3004
description ospf L3 area0 staff VRF
ip address 10.196.2.41 255.255.255.248
router ospf 101 vrf student
router-id 10.196.1.1
redistribute bgp 800 metric-type 1 subnets
passive-interface default
no passive-interface Vlan3001
no passive-interface Vlan3003
network 10.196.1.0 0.0.0.255 area 0
router ospf 102 vrf staff
router-id 10.196.2.1
redistribute bgp 800 subnets
no passive-interface Vlan3002
no passive-interface Vlan3004
network 10.196.2.0 0.0.0.255 area 0
router ospf 100
router-id 10.196.12.1
no passive-interface Vlan100
no passive-interface Vlan101
network 10.196.12.0 0.0.0.255 area 0
router bgp 800
bgp log-neighbor-changes
address-family ipv4
exit-address-family
address-family ipv4 vrf staff
redistribute ospf 102 match internal external 1 external 2
exit-address-family
address-family ipv4 vrf student
redistribute ospf 101 match internal external 1 external 2
exit-address-family
ip route 0.0.0.0 0.0.0.0 10.192.32.1
end
Dstr1 config:
Distr1#show run
Current configuration : 8565 bytes
! Last configuration change at 22:18:20 UTC Wed Aug 14 2019 by test
version 16.6
no service pad
hostname Distr1
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
rd 800:2
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
rd 800:1
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
ip routing
transceiver type all
monitoring
vlan 100
name ospf100
vlan 3001
vlan 3002
interface Loopback0
ip address 10.196.12.2 255.255.255.248
interface Loopback1
description OSPF router LSA id student VRF
ip address 10.196.1.2 255.255.255.248
interface Loopback2
description OSPF router LSA id staff VRF
ip address 10.196.2.2 255.255.255.248
interface Loopback10
ip address 10.162.11.254 255.255.255.0
interface Loopback11
ip address 10.64.11.254 255.255.255.0
ip address 10.194.177.232 255.255.240.0
speed 1000
negotiation auto
interface Vlan100
ip address 10.196.12.10 255.255.255.248
interface Vlan3001
ip address 10.196.1.10 255.255.255.248
interface Vlan3002
ip address 10.196.2.10 255.255.255.248
router ospf 4001 vrf student
router-id 10.196.1.2
redistribute ospf 101 subnets match internal external 1 external 2
network 10.162.10.0 0.0.0.255 area 101
network 10.162.11.0 0.0.0.255 area 101
router ospf 4002 vrf staff
router-id 10.196.2.2
redistribute ospf 102 subnets match internal external 1 external 2
network 10.64.10.0 0.0.0.255 area 102
network 10.64.11.0 0.0.0.255 area 102
router ospf 4000
router-id 10.196.12.2
end
Distr2 config:
forgot the Distr2 config
Distr2#show run
Current configuration : 8543 bytes
! Last configuration change at 22:36:34 UTC Wed Aug 14 2019 by test
version 16.6
no service pad
hostname Distr2
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
rd 800:2
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
rd 800:1
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
ip routing
vtp mode transparent
vlan 101
name ospf101
vlan 3003
vlan 3004
interface Loopback0
ip address 10.196.12.3 255.255.255.248
interface Loopback1
ip address 10.196.1.3 255.255.255.248
interface Loopback2
ip address 10.196.2.3 255.255.255.248
ip address 10.162.21.254 255.255.255.0
ip address 10.64.21.254 255.255.255.0
ip address 10.194.177.233 255.255.240.0
speed 1000
negotiation auto
interface Vlan101
ip address 10.196.12.42 255.255.255.248
ip ospf 100 area 0
interface Vlan3001
no ip address
interface Vlan3003
ip address 10.196.1.42 255.255.255.248
interface Vlan3004
ip address 10.196.2.42 255.255.255.248
router ospf 5001 vrf student
router-id 10.196.1.3
network 10.162.20.0 0.0.0.255 area 5001
network 10.162.21.0 0.0.0.255 area 5001
router ospf 5002 vrf staff
router-id 10.196.2.3
network 10.64.20.0 0.0.0.255 area 5002
network 10.64.21.0 0.0.0.255 area 5002
router ospf 5000
router-id 10.196.12.3
end
Distr2# show ip route vrf student
O IA 10.162.11.254/32 [110/4] via 10.196.1.41, 02:10:56, Vlan3003
C 10.162.21.0/24 is directly connected, Loopback10
L 10.162.21.254/32 is directly connected, Loopback10
O 10.196.1.1/32 [110/2] via 10.196.1.41, 02:11:00, Vlan3003
O 10.196.1.2/32 [110/4] via 10.196.1.41, 02:11:00, Vlan3003
L 10.196.1.3/32 is directly connected, Loopback1
O 10.196.1.8/29 [110/3] via 10.196.1.41, 02:11:00, Vlan3003
L 10.196.1.42/32 is directly connected, Vlan3003
Distr2# show ip route vrf staff
O IA 10.64.11.254/32 [110/4] via 10.196.2.41, 02:11:08, Vlan3004
C 10.64.21.0/24 is directly connected, Loopback11
L 10.64.21.254/32 is directly connected, Loopback11
O 10.196.2.1/32 [110/2] via 10.196.2.41, 02:11:12, Vlan3004
O 10.196.2.2/32 [110/4] via 10.196.2.41, 02:11:12, Vlan3004
L 10.196.2.3/32 is directly connected, Loopback2
O 10.196.2.8/29 [110/3] via 10.196.2.41, 02:11:12, Vlan3004
L 10.196.2.42/32 is directly connected, Vlan3004
