Do we have command "default interface x/y" in ASR9000?
wfqk
Level 5
Level 5
Hi We can use command "default interface" to remove all configurations on an interface usually. but it seems like that the command cannot work in ASR 9000. Do you think there are some other commands for it? Thank you
tradzwon
try using "no interface GigE0/0/0/x" from config-interface prompt.
This should erase everything.
