11-26-2024 02:32 PM
We have a pair of ASAs, and we use the prompt hostname state command to display the active or standby status in the hostname.
Now, we have a pair of FTDs managed via FMC. We sometime need to SSH into the FTDs to check the configuration, we are looking for a similar command to display their active or standby status in the hostname.
Could you please advise if such a command exists for FTD?
Thank you!
Best regards,
Loc
Solved! Go to Solution.
11-26-2024 02:48 PM
There is a similar discussion here in the forum with a suggestion to use FlexConfig policy. You may explore this possibility
11-26-2024 02:48 PM
11-27-2024 10:15 AM
Thanks. I tried ""prompt hostname priority state"" in FlexConfig policy and it worked.
