Does 2951 support VPN connectivity by default ?
Infuscomus
Problem: I have an old 2851 with VPN module.
Currently, there are IPSEC crypto-connections in use that go through an EIGRP tunnel.
Showing crypto engine br I get: VPN Module (HW) status enabled.
Showing crypto maps, I see that there are leased some active ones.
Showing aaa: there are active sessions.
According to the documentation here:
http://www.cisco.com/c/en/us/products/collateral/routers/2900-series-integrated-services-routers-isr/data_sheet_c78_553896.html ,
The 2951 has embeded IPSec support.
The question is: Is a VPN additional module (3DS/AES encryption module) needed for the 2951 or will the connections work without it ?
Hello.
It will work, but requires SEC/K9 license (and general image, not NPE):
https://www.cisco.com/c/dam/en/us/products/collateral/routers/3900-series-integrated-services-routers-isr/qa_c67_606268.pdf
Also if you want to do IPSec for traffic rates higher than 85M unidirectional.
Hello.
Is the same valid for the ISR 4351 series ?
