HSRP Issue between two Core switches
I have two core switches connected together with trunk interface ,SW-1 is the Main and SW-2 is the backup , i applied HSRP on the SVI on both switches with high priority on SW-1, now for testing i opened ping session on host (100.100.100.100 ) to ping interface VLAN 100 (100.100.100.1) the ping is working well, but when i shutdown interface VLAN100 on SW-1 the SW-2 show command "show standby brief" display that SW-2 is become the Active for VLAN100 but the ping is not working. same issue for all SVI.
Here is my configuration on both switches, Note: SW-2 have the same configurations , routes, ACL like SW-1 except the SVI IP addresses
SW-1:
interface Vlan1
 ip address 192.168.1.2 255.255.255.0
 standby 0 ip 192.168.1.1
 standby 0 priority 110
 standby 0 preempt
interface Vlan30
 ip address 192.168.30.2 255.255.255.0
 standby 0 ip 192.168.30.1
 standby 0 preempt
interface Vlan100
  ip address 100.100.100.2 255.255.255.0
 standby 0 ip 100.100.100.1
 standby 0 preempt
SW-2:
interface Vlan1
 ip address 192.168.1.3 255.255.255.0
 standby 0 preempt
interface Vlan30
 ip address 192.168.30.3 255.255.255.0
 standby 0 preempt
interface Vlan100
 ip address 100.100.100.3 255.255.255.0
 standby 0 preempt
SHOW on SW-1 ( show standby brief):
Interface   Grp  Pri   P   State     Active          Standby             Virtual IP
Vl1             0    110  P   Active    local           192.168.1.3        192.168.1.1
Vl30           0    110  P   Active    local           192.168.30.3      192.168.30.1
Vl100         0    110  P   Active    local           100.100.100.3    100.100.100.1
SHOW on SW-2 ( show standby brief):
Vl1             0    100  P   Standby    192.168.1.2           local                192.168.1.1
Vl30           0    100  P   Standby    192.168.30.2         local                192.168.30.1
Vl100         0    100  P   Standby    100.100.100.2       local                100.100.100.1
13 Replies 13
johnlloyd_13
Level 9
Level 9
hi,
could you post a brief network topology of your switching environment?
could you 'shutdown' or disconnect the trunk link between the core switches instead of the SVI (VLAN 100)?
here is the topology connection, note again the SW-2 has copy of the same configuration of SW-1 except the SVI interfaces, for the trunk link i can't disconnected it we are working in live environment
hi,
thanks for the diagram!
you may want to schedule a window time to test failover/HSRP.
alternatively, you could do on core SW-2 and observe:
SW-2
interface Vlan100
 standby 0 priority 150
i did but without any success
hmm... next time you check it, have a look at the show mac address table on the edge switches and see which switch it's going towards for the HSRP virtual mac.
thanks my friend, i disconnect the physical cable it self and it's working fine :)
remain only one issue, on of SVI which i have there is an access-list applied on this SVI to limit access for specific servers, in "show standby brief" i get only this SVI is UNKOWN for the standby router, then when i remove the access-list it became active
interface Vlan20
 ip address 192.168.20.3 255.255.255.0
 ip access-group 102 in
 standby 0 ip 192.168.20.1
 standby 0 preempt
With Access-list i get this output , on SW-1 :
Vl20        0    110 P Active  local           unknown         192.168.20.1
With Access-list i get this output , SW-2:
Vl20        0    100 P Active  local           unknown         192.168.20.1
after removing access list-SW-1:
Vl20        0    110 P Active  local           192.168.20.3    192.168.20.1
after removing access list-SW-2:
Vl20        0    100 P Standby 192.168.20.2    local           192.168.20.1
what i should add in access list to allow both core switches see each other as active or standby ?
you need to allow the hsrp control traffic on the acl
See this doc - if you stay on hsrp v1 you need permit from svi to 224.0.0.2 for udp 1985 but remember to change multicast address to 224.0.0.102 if you move to v2
http://www.cisco.com/c/en/us/support/docs/ip/hot-standby-router-protocol-hsrp/9281-3.html
thanks my friend , it's working fine now  :)
Hi - thats great!
If this issue is now closed please mark it as answered :)
How long do you actually leave it down when you test? You could just be seeing a delay in spanning tree convergence...
actually i leave it around 2 minutes as am using Rapid-PVST
Can you try configuring vlan 100 using a different HSRP group number and retest.
Just for vlan 100 ie. don't configure the new group number under any of your other SVIs.
Jon
