Does 877W ADSL router support VCMUX?
dlau
My ISP in NZ only support VC mux encapsulation for ADSL connection. Is there a VC MUX equivalent in 877W?
purohit_810
Level 5
Level 5
Your ISP only can give you better idea related to product support because they are maintaioning MUX.
Second, if you are seating at ISP end... you can contact to MUX vendor and find out.
Most probably, IT SHOULD SUPPORT.. Because it is no where related to router.
Mux vendors are making, product such standard way.
Still You can get some idea from
http://www.cisco.com/en/US/tech/tk175/tk349/technologies_configuration_example09186a008009413e.shtml
You can also force up router to get the signal from MUX by
encapulation mux-ppl {What ever encapulation give by ISP}
That command avalable into above link document.
Dharmesh Purohit
ahmednaas
Level 4
Level 4
Check this link for Cisco routers NZ ADSL configurations:
http://www.ifm.net.nz/cookbooks/800-isr-wizard.html
