Keepalive over GRE tunnel on VRF - bug ??
ftrousse
In this post :
SOURCE-IP@ = SOURCE IP@ of the GRE tunnel = INTERNET IP@ of the router
GATEWAY-IP@ = next hop to internet
DESTINATION-IP@ = DESTINATION IP@ of the GRE tunnel = INTERNET IP@ of the remote router
I have 2 VRF on a cisco 2811 running a c2800nm-adventerprisek9-mz.124-12.bin
one INTERNET with an internet access
One INTERNAL with a tunnel interface using the vrf INTERNET to route tunnel packets.
Everything works well if i don't use the "keepalive" command on the tunnel interface.
If i put the "keepalive" command on the tunnel of the 2811, everything is still OK
but once i put the "keepalive" command on the remote router, the tunnel interface on the remote tunnel goes down.
and it appears on the log of the 2811
Feb 19 14:35:41: IP: s=SOURCE-IP@ (Tunnel25), d=DESTINATION-IP@, len 32, unroutable
It looks than the router use the INTERNAL routing table to reply to keeplives, whereas to use the INTERNET routing table specified by the "tunnel vrf INTERNET"
So i put the following static route on the global table of the 2811:
ip route vrf INTERNAL DESTINATION-IP@ 255.255.255.255 FastEthernet0/0 GATEWAY-IP@
And the tunnel goes UP/UP on the remote router.
Is it a bug or am i missing something ?
the 2811 configuration :
ip vrf INTERNAL
rd XXX:108
route-target export xxx:108
route-target import xxx:108
route-target import xxx:109
route-target import xxx:100
ip vrf INTERNET
rd XXX:100
route-target export xxx:100
interface Tunnel25
ip vrf forwarding INTERNAL
ip address 1.1.1.1 255.255.255.252
ip mtu 1500
ip ospf authentication-key 7 xxxxxxxxxxxxxxxxxxxx
ip ospf cost 20
keepalive 10 3
tunnel source SOURCE-IP@
tunnel destination DESTINATION-IP@
tunnel key 111222333
tunnel checksum
tunnel vrf INTERNET
interface FastEthernet0/0
ip vrf forwarding INTERNET
ip address SOURCE-IP@ 255.255.255.128
ip access-group INTERNET-IN in
ip access-group INTERNET-OUT out
ip nat outside
ip virtual-reassembly
load-interval 30
duplex full
speed 100
ip route vrf INTERNET 0.0.0.0 0.0.0.0 GATEWAY-IP@ name INTERNET
and the route i have to add if i want to use keepalive on the remote router:
ip route vrf INTERNE DESTINATION-IP@ 255.255.255.255 FastEthernet0/0 GATEWAY-IP@
didyap
Level 6
Level 6
It is required that source and destination IP addresses of a tunnel are from Global Routing Table context. IP address of
tunnel interface itself may be in VRF, but it breaks keepalive mechanism. The problem is that keepalive arrives into Global table, while sender expects it to be in VRF context.With leaking static route may allow keepalive packet to be seen from VRF when it is decapsulated in the Global table.
