Does Anyone Know how to Set Option 150 under DHCP on ZTE ZXR10 Switch
akamps
Hello Team, i need help configuring option 150 on a ZTE ZXR10 switch so that Cisco phones can reach the TFTP server. I don't seem to know how to do that.
Hello
The DHCP options are set on the DHCP scoped within the dhcp server, to forward UDP 150 from your network towards the ddcp server then you can set that the L3 switch
conf t
ip forward-protocol udp 150
int x/x
ip helper-address x.x.x.x (dhcp server)
Kind Regards
Paul
@paul driver, not going to work on a ZTE-brand switch.
Hello @Leo Laohoo
thanks for the feedback -  TBH when i mentioned "L3 switch" I was thinking a cisco L3 switch/rtr and not this ZTE running at L3, however it wasnt clear so apologies to the OP.
Kind Regards
Paul
