Vlan mapping on lan ports - ISR 1111
Yagel Himan
Hey
Is it possible to configure vlan mapping on one of the lan ports of Cisco ISR 1111 (Version 17.3.4a)?
7 Replies 7
and if vlan-mapping doesn't appear there?
if not appear then the Ver not support this feature
denniska1996
Hello Yagel
I don't think is it possible to do vlan mapping on router
below an example of an operational 1101 router,
I doubt the 1111 will behave much different (It is 1000 series or 1100 series)
have you already enabled privileged mode before trying to make changes ?
NAME: "Chassis", DESCR: "IR1101 Base Chassis"
PID: IR1101-K9 , VID: V07 , SN: *********
router#sho int status ! (here you allready can see vlan 2 assigned to the ports)
Port Name Status Vlan Duplex Speed Type
Gi0/0/0 notconnect routed auto auto Auto Select
Fa0/0/1 notconnect 2 auto auto 10/100BaseTX
Fa0/0/2 connected 2 a-half a-10 10/100BaseTX
Fa0/0/3 connected 2 a-full a-100 10/100BaseTX
Fa0/0/4 notconnect 2 auto auto 10/100BaseTX
router #sho run int fa0/0/1
Building configuration...
Current configuration : 85 bytes
interface FastEthernet0/0/1
switchport access vlan 2
spanning-tree portfast
end
hey
thanks for your reply, but i'm tring to configure VLAN-MAPPING
sorry I misunderstood the question
when using  the Cisco Feature Navigator tool, there is no referral to vlan mapping as a supported feature
