Does Cisco Catalyst 2960-8TC support bandwidth limit control..
p-madsen.actona
We are about to share a 10 MBit ISP connection with 2 others companies, and they are going to split the bill up into 3,3 and 4 Mbit, so we where thinking that we could setup a switch before their and ours router and provide them with a static IP from our ISP. But is it possible to set a bandwidth limit on the ports of a Cisco Catalyst 2960-8TC, so that we can set a limit of 3,3 and 4 on 3 ports - so that they actually gets what they pay for ???
Thx.
/Peter
kamran_Roostaee
You can set limit on catalyst switch with srr-queue bandwidth limit  interface command but IOS should be later than 12.2(25). you should set speed to 10Mbps first anf then set limit percentage
