does cisco vg350 (analog voice gateway) support ether channel??
hi guys,
 i am trying to configure a vg350 gateway (which has 3 gig interfaces) with layer 3 eitherchannel. it doesnt seem to take the commands  for port channel. does it support?
:vg350-universalk9-mz.SPA.154-3.M3.bin
Technology Package License Information for Module:'vg350'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data None None None
NtwkEss None None None
CollabPro None None None
Router(config)#int po1
Router(config-if)#ip add 10.10.10.3 255.255.255.0
% IP addresses may not be configured on L2 links.
Router(config-if)#no sw
Router(config-if)#no switchport
Command rejected: not allowed under port channel.
Router(config-if)#no switchport mo
Router(config-if)#no switchport mode
Router(config-if)#no switchport ?
  access    Set access mode characteristics of the interface
  mode      Set trunking mode of the interface
  priority  Set 802.1p priorities
  trunk     Set trunking characteristics of the interface
  <cr>
Router(config-if)#no switchport tr
Router(config-if)#no switchport trunk ?
  allowed        Set allowed VLAN characteristics when interface is in trunking
                 mode
  encapsulation  Set trunking encapsulation when interface is in trunking mode
  native         Set trunking native characteristics when interface is in
                 trunking mode
% Incomplete command.
Router(config-if)#no switchport trunk all
Router(config-if)#no switchport trunk allowed
Router(config-if)#no switchport trunk allowed  ?
  vlan  Set allowed VLANs when interface is in trunking mode
Router(config-if)#no switchport trunk en
Router(config-if)#no switchport trunk encapsulation
Router(config-if)#
Router(config-if)#
Router(config-if)#
Router(config-if)#exi
Router(config)#int g0/1
Router(config-if)#chann
Router(config-if)#chann?
% Unrecognized command
luis_cordova
luis_cordova
Hi @vijendra Saravanamuthu
I found in some forums that that device does not support EtherChannel.
They recommended use BVI
https://www.cisco.com/c/en/us/support/docs/lan-switching/integrated-routing-bridging-irb/200650-Understanding-Bridge-Virtual-Interface.html
