Does inverse arp forward routing protocols?
Tannersummers
I know by doing the, frame-relay map ip <x.x.x.x> (dlci #) broadcast routing protocols work in my lab inside of packet tracer. But when I was just doing inverse arp dynamically, "Serial0/0 (up): ip 80.53.32.1 dlci 25, dynamic, broadcast, CISCO, status defined, active" the routing protocols do not work. Is there a way to have inverse arp to work with broadcast?
seemakha
Check the thread below it might answer your queries.
https://supportforums.cisco.com/discussion/9108846/inverse-arp-and-nbma-networks
Cool, i'll read it in just a big. Would you also happen to know if a cloud in Packet Tracer is able to work from point-to-point (sub interfaces) frame relay networks? I am attempting it and I can't get the cloud to except more then a few mappings of the sub interfaces dlci's so only half of it works, the rest I get an error message
