Does ISR4431 support port channels?
pkemp
I want to aggregate interfaces on my ISR4431 to a Cat9500 switches and run dot1q sub-interfaces in a 'router-on-a-stick' mode. Running IOS XE 15.5.
Peter
marce1000
 - Seems to do according to this article :
         https://thenetworkstack.com/new-cisco-isr4000-series-routers/
 M.
I believe the OP is asking about whether or not port-channel sub-interfaces are supported.
In my experience they can, but you can try it by attempting to create a new port-channel on your router (just create the interface then the sub-interface in the first instance).
For example, if using 802.1Q trunks between your switch and router:
int port-channel 1
int-port-channel 1.100
 encapsulation dot1q 100
 ip address 1.2.3.4 255.255.255.0
int port-channel 1.200
 encapsulation dot1q 200
 ip address 3.4.5.6 255.255.255.0
Then port-channel 1 would be tied to your physical interfaces.
