Does the IR1101 support IRB or Bridge Domains?
Stephen Craven
Level 4
Level 4
As I understand it, the Integrated Routing & Bridging (IRB) of vanilla IOS has been replaced with Bridge Domains on IOS XE.
When I attempt to follow available instructions for configuring Bridge Domains using an IR1101, I find some commands are missing.
Is there a way to bridge the Gi 0/0/0 routed port with the switched LAN ports?
Stephen
billo
I have the same query.
One workaround is to change GI 0/0/0 to a switchport and use vlans.
It's not a great workaround for our use case as we want the option to bring any double, or single tagged traffic in to a bridge-domain on GI 0/0/0 (GI 0/0/0 terminates VDSL).
