vbr-nrt command
aajackson
In this configuration example (from a CISCO887VA) will the the outbound traffic be restricted to 228K?
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/38
  vbr-nrt 288 288
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
In this case the line is clocked upstream at 1200Kbps:
RTR#sh atm int atm 0
Interface ATM0:
AAL enabled:  AAL5,, Maximum VCs: 4, Current VCCs: 1
VCIs per VPI: 1024,
Max. Datagram Size: 1658
PLIM Type: ADSL - 1200Kbps Upstream, DMT, TX clocking: LINE
2915278 input, 7233878 output, 53305627 IN fast, 49814550 OUT fastVBR-NRT : 288
Avail bw = 912
Config. is ACTIVE
Thanks in advance
Andy Jackson
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Yes.  Keep in mind, ATM (within the cloud) can have a cap on the bandwidth used by the PVC lower than the physical hand-off.
Also if this is an ADSL, your upstream bandwidth is often less than downstream bandwidth, and even downstream might be less than physical handoff's bandwidth.
