Showing results forĀ
Search instead forĀ
Did you mean:Ā
dot1q subinterface mapping to each vrf in a Port-Channel of ASR1002
lapkei2
Does ASR1002 supports dot1q subinterface mapping to each vrf in a Port-Channel? and with BFD enabled?
For example
ASR1002#conf t
interface Port-channel1
no negotiation auto
no bfd echo
lacp min-bundle 2
!interface GigabitEthernet0/0/1
no ip address
no negotiation auto
channel-group 1 mode active
interface GigabitEthernet0/0/2
no ip address
no negotiation auto
interface Port-channel1.101
encapsulation dot1Q 101
ip vrf forwarding first_vrf
ip address 10.10.10.1 255.255.255.252
bfd interval 250 min_rx 250 multiplier 3
no bfd echo
service-policy input COS-IN
interface Port-channel1.201
encapsulation dot1Q 201
ip vrf forwarding second_vrf
ip address 10.10.10.5 255.255.255.252
no bfd echo
9 Replies 9
Philip D'Ath
Hmm, BFD on the port-channel itself.  I don't think that makes sense.  Surely you would only have it on the physical members, GigabitEthernet0/0/1 and GigabitEthernet0/0/2.  BFD is trying to detect a physical failure.
Thanks Philip, How about port-channel subinterface with dot1q and vrf mapping?
That is fine.
so, the command is supported for port-channel subinterface with dot1q and vrf mapping?
Thanks, I read it before as it doesn't mention about VRF and BFD on port-channel
BFD on the physical interfaces, vrf on the sub-interfaces of the port-channel.
So, as the bfd neighbor is on vlan 101 and vlan 201, the actual configuration will be?
ASR1002#conf t
no ip address
no negotiation auto
lacp min-bundle 2
no ip address
no negotiation auto
no ip address
no negotiation auto
service instance 1 ethernet
no bfd echo
service instance 2 ethernet
no bfd echo
Negative (with regard to BFD).  I would expect it to be:
 no ip address
 no negotiation auto
no bfd echo
 no ip address
 no negotiation auto
no bfd echo
