Double NATing
Iloveyou
Assume I have a 172.16.0.0/16 network, it is then Nated to a 192.168.1.0/24 network.
This 192.168.1.0/24 is then NAT via a firewall to a public ip so that there is internet access.
So being a routing issue, how can I route to the 172.16.0.0/16 network.
After vpn into firewall, I can only reach the 192.168.1.0/24 but not the 172.16.0.0/16
5 Replies 5
Torbjørn
You can do one of the following:
  • Port forward the specific devices you wish to reach from the firewall.
  • Add a route for 172.16.0.0/16 on your firewall towards the 192.168.1.0/24 address of your router. Then add an exception for traffic destined to your firewall address in the 192.168.1.0/24 network to the ACL you are using in your NAT config, such that your return traffic isn't NATed.
  • Add a route to the 172.16.0.0/16 network on your firewall towards the router and set up source-nat "the other way" on the router if this is supported.
  • Create a tunnel between the firewall and the router and add a route to the 172.16.0.0/16 network though your tunnel. Such that the traffic isn't affected by the configured NAT.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Please do me a favour and give me some commands for 2nd or 3rd for better illustration.
Hello
The rtr that is natting 172.16.0.0/16 towards the Fw  is the key it will need to be dynamic  host to host NAT for connection to be successful
Alternatively you could just have a static route from the FW towards that rtr for 172.16.0.0/16 subnet and perform nat on the Fw for it thus removing NAT from the rtr.
Kind Regards
Paul
public NATing and dual NAT in same FW ?
If yes that not work.
The FW do only one NATing for traffic here it do NATing to 192.168.1.0 or 192.168.1.0 to public not both.
you can make 172.16.0.0 NAT to 192.168.1.0 only if traffic go via VPN or other
and NATing to public if traffic have destination any
