Static NAT translations and ACLs with dual failover ISP config
DazOG
I'm building a dual ISP failover config, which I believe I have got sorted out (second to-be-primary ISP isn't online yet to test, but the "ip sla" etc stuff is using the correct failback route).
Where I'm a bit confused is how to handle static NAT translations for services behind the router.
On my existing single ISP setup this is simple - an ip nat inside source static tcp 10.0.0.1 100 2.2.2.2 100 extendable entry along with a corresponding permit tcp any host 2.2.2.2 eq 100 ACL entry to allow the traffic inbound.  This is all working.
When the second ISP comes online, I presume I will have to do a second static translation to the corresponding external IP (as I understand it "extendable" is for this exact purpose) ?  In terms of the ACL, do I just create an object-group network with both external IPs in, and change the ACL to permit tcp any host object-group ISP1-ISP2-EXT-IP eq 100, or do I do each line separately, or something else entirely?
Is this the correct way to do it?  e.g. the config would end up looking something like this:
object-group network ISP1-ISP2-EXT-IP
host 2.2.2.2
host 3.3.3.3
ip nat inside source static tcp 10.0.0.1 100 3.3.3.3 100 extendable
ip access-list extended INCOMING
permit tcp any object-group ISP1-ISP2-EXT-IP eq 100
 Does that sound right?  Thanks in advance!
you need to ACL one for each IP
INCOMING-ISP1 and INCOMING-ISP2
and apply each one under the ISP interface the traffic come from.
Thanks A Lot
MHM
6 Replies 6
DazOG
I forgot to add - DNS failover will be done externally so that a FQDN that people access will point to the currently available IP.
Thanks A Lot
MHM
Thanks. Both ISP facing Ethernet interfaces are in the same “OUTSIDE” zone, which has an ACL applied via a class-map & policy-map.
So I can’t use an object-group to cover both IPs, I have to have two unique and explicit lines in the ACL?
NO you can use object-group but this make CPU check two line (or more) for each traffic.
that not need.
make two ACL make CPU check only one line.
DazOG
Clever, thanks
