DR Site configuration questions!
vrushali06
We have an MPLS network where all the remote sites(50) connect via MPLS to the datacenter which has a 3945 router. Now we are setting up a DR site which will also be connected via MPLS to this same network. The DR site also has an internet connection which will be connected to ASA. We do not have a fiber connection between the DR and the datacenter due to costs and will use MPLS for everything.
We use EIGRP for advertising our networks internally over MPLS. All the remote sites have their internet default route towards the datacenter ASA. How can I set up the DR router to send only the needed networks over the WAN and send the internet traffic over the DR ASA. If I do policy routing then if the DR ASA fails then internet traffic will not automatically failover to the Datacenter ASA. Does anyone have a suggestion and maybe a sample config. When the datacenter is down we also then need all the sites to failover to the DR ASA for internet and the DR site for all applications which when we advertise the server network from there it will automatically fail over to the DR.
Since we are a L3 network we cannot advertise our server network on the DR site till the datacenter is down. How is everyone doing this or does someone have a simple solution/idea to do this in minimum time.?
Thanks so much.
plumbis
Level 7
Level 7
You might be able to use an offset list on the DR MPLS router. For the incoming default route you'll add a large value to the metric to make it less prefered than the locally originated route.
At the same time you'll use an outbound for the default route originated in the DR to make it much less prefered than the default in the rest of the network.
Here is a document that talks about modifying EIGRP metric and one of the tools they use is the offset list.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c2d96.shtml#modifycompositemetric
Good Luck!
-Pete
