Drop: 9614 encapsulation failed
kar.somnath
We are getting packet drop in our network passing through WAN Router. Please find the below command output from WAN router.
sh interfaces gi0/1
Input queue: 0/75/16058/0 (size/max/drops/flushes); Total output drops: 0
sh ip traffic
Drop:  9614 encapsulation failed, 0 unresolved, 0 no adjacency
Can you please let me know how to resolve this issue. Please let me know if you need any other details.
som
5 Replies 5
Calin C.
Level 5
Level 5
This encapsulation failed drops, increase constantly and fast or you just have them over a longer period of time?
Usually this "encapsulation failed" indicates that the router had no ARP request entry and therefore did not send a datagram.
If they increase in a rapid manner, check your routing configuration and forwarding table. Your device may receive a lot of packets that it doesn't know how to handle due to inconsistent routing / forwarding table.
HTH,
Calin
Hi Calin,
I have checked that encapsulation failed drops is not increase constantly.
Thx,
som
but input queue drop increasing rapidly
Before-
Now-
Input queue: 0/75/16098/0 (size/max/drops/flushes); Total output drops: 0
This may be just because you have qos or policing on this interface.
In that case, it is normal behaviour.
regards,
Leo
lgijssel
Level 9
Level 9
You can look this up in the command reference:
http://www.cisco.com/en/US/docs/ios/12_1/iproute/command/reference/1rdip.html#wp1020634
Look at table 23:
Usually indicates that the router had no ARP request entry and therefore did not send a datagram.
regards,
Leo
