Drops in WAN link
pgamage
We have 512 link and observe output drops and application timeouts. Link utilization is not very high.
When ping with 1500 bytes, it shows output drops and when ping with default packet size, no output drops observed.
Service policy also in effect and shows some drops.
I have attached the screen captuers.
Is there anything wrong with serial link?
6 Replies 6
paolo bevilacqua
When working with CLI devices, please copy and past text instead of using screenshots.
Here is the command out puts
R1#sh int serial 3/2:0 | in rate
  Queueing strategy: weighted fair
  30 second input rate 177000 bits/sec, 223 packets/sec
  30 second output rate 208000 bits/sec, 226 packets/sec
R1#
R1#sh int serial 3/2:0 | in drops
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 95
  Output queue: 0/2000/64/0 (size/max total/threshold/drops)
R1#
R1#
R1#
R1#ping 1.1.1.1 rep
R1#ping 1.1.1.1 repeat 200
Sending 200, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (200/200), round-trip min/avg/max = 4/5/8 ms
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 98
R1#
R1#ping 1.1.1.1 repeat 200 si 1500
Sending 200, 1500-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Success rate is 97 percent (194/200), round-trip min/avg/max = 24/27/64 ms
R1#
R1#
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 120
R1#
R1#sh pol
R1#sh policy-map in
R1#sh policy-map interface ser 3/2:0
Serial3/2:0
  Service-policy input: ABC
    Class-map: class-default (match-any)
      33346 packets, 4157374 bytes
      30 second offered rate 197000 bps, drop rate 0 bps
      Match: any
        30 second rate 197000 bps
      police:
          cir 512000 bps, bc 64000 bytes, be 128000 bytes
        conformed 33298 packets, 4017708 bytes; actions:
          transmit
        exceeded 113 packets, 131400 bytes; actions:
          drop
        violated 14 packets, 13444 bytes; actions:
          drop
        conformed 194000 bps, exceed 0 bps, violate 0 bps
  Service-policy output: ABC
      33822 packets, 4114448 bytes
      30 second offered rate 196000 bps, drop rate 0 bps
      Match: any
        30 second rate 196000 bps
      police:
        conformed 33651 packets, 3956556 bytes; actions:
          transmit
       exceeded 154 packets, 154472 bytes; actions:
          drop
        violated 3 packets, 3084 bytes; actions:
          drop
        conformed 191000 bps, exceed 0 bps, violate 0 bps
R1#
Why you just don't believe that it is your policing working? It is doing what it is supposed to do - drop traffic above CIR. You may want to chenge your policing config if you want to allow more traffic to pass through.
Nik
HTH,
Niko
Just to add to the coment above. Interface utilization can be low in average but can have short bursts of traffic. Those cause policing to drop the overhead.
Nik
HTH,
Niko
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Nik has likely touched upon the most likely issue, i.e. low average utilization can have have short traffic bursts.
Look at your original post's policy.GIF.  The second interfaces shows low average offered rate, but the policer is dropping some packets.
More likely than there being something wrong with you serial link, your policing policy might be suboptimal.
perform an extended ping changing dynamically the size of the packet you send out.
It maybe be useful to understand the max MTU you are at the moment able to transmit.
Alessio
