06-21-2006 09:17 AM - edited 03-03-2019 01:04 PM
We are planning to migrate our WAN to a DS3 backbone.
Can any one help me with the following queries:-
1) How can I connect a unframed DS3 link directly to a 7206 router.
2) If we need to use ATM, can someone help me with the configuraiton details involved.
Help would be much appreciated.
06-21-2006 09:42 AM
Just use the appropriate serial PA card (PA-E3 or PA-T3). Configure the link as any other serial link.
Regarding the ATM, i think that the creation of a point to point subif would be the simplest solution, but my ATM knowledge is limited :)
Chris.
06-21-2006 10:44 AM
(1) Make sure you buy the appropriate card. If you go with a serial DS3 (PA-T3), don't waste extra money on the multi-channel DS3 card (PA-MC-T3). If you go with ATM, buy an ATM DS3 card.
(2) I just turned up a ATM DS3 Internet connection with ATT. The config is rather simple. Drop me a line if you go that route.
David
