DSCP Packet Failing to Remarking using a Service Policy
hedg1416p
I am trying to remark inbound Skype for Business Online audio and video traffic with ef, af31 and af41 DSCP values using the following configuration. When I check for packet matches against the service-policy it doesn't show any packet matches (apart from a few odd packets). I can confirm using wireshark on my workstation that the port ranges are correct and the packets are not being remark correctly.
I have just upgraded the router ASR1002 to 15.5(3)S5 as it was previously running an old version. The configuration matches those shown in example 2 of http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_mqc/configuration/xe-3s/qos-mqc-xe-3s-book/qos-mrkg.html.
Any assistance with this would be much appreciated
ip access-list extended SfBO-APPSHARE
 permit udp any any range 50040 50059
 permit tcp any any range 50040 50059
ip access-list extended SfBO-AUDIO
 permit udp any any range 50000 50019
 permit tcp any any range 50000 50019
ip access-list extended SfBO-VIDEO
 permit udp any any range 50020 50039
 permit tcp any any range 50020 50039
class-map match-all SfBO-APPSHARE
 match access-group name SfBO-APPSHARE
class-map match-any SfBO-AUDIO
 match access-group name SfBO-AUDIO
class-map match-all SfBO-VIDEO
 match access-group name SfBO-VIDEO
policy-map SfBO-DSCP-REMARK
 class SfBO-VIDEO
  set dscp af41
 class SfBO-APPSHARE
  set dscp af31
 class SfBO-AUDIO
  set dscp ef
interface GigabitEthernet0/0/0
description **to ISP**
interface GigabitEthernet0/0/0.100
service-policy input SfBO-DSCP-REMARK
sh policy-map int
  Service-policy input: SfBO-DSCP-REMARK
    Class-map: SfBO-VIDEO (match-all)
      15 packets, 8673 bytes
      30 second offered rate 0000 bps, drop rate 0000 bps
      Match: access-group name SfBO-VIDEO
      QoS Set
        dscp af41
          Marker statistics: Disabled
    Class-map: SfBO-APPSHARE (match-all)
      16 packets, 3139 bytes
      Match: access-group name SfBO-APPSHARE
      QoS Set
        dscp af31
    Class-map: SfBO-AUDIO (match-any)
      14 packets, 2950 bytes
      Match: access-group name SfBO-AUDIO
      QoS Set
        dscp ef
    Class-map: class-default (match-any)
      75835834 packets, 70822436288 bytes
      30 second offered rate 680902000 bps, drop rate 0000 bps
      Match: any
as far as I recall, this is a bug on the ASR 1000, QoS ACL counters are not supported.
I am not sure if this command is available in IOS 15.5:
platform qos marker-statistics
Otherwise, upgrade to an XE release...
Hello Georg,
the router is already running an XE version - Cisco IOS XE Software, Version 03.16.05.S - Extended Support Release
Also the enabling 'platform qos marker-statistics' has a cpu impact so I am reluctant to enable it especially as it only affects the packet marked section and not the packet matching section.
Service-policy input: mark-traffic Class-map: jabber-video (match-all)
850 packets, 51000 bytes  see note 1
5 minute offered rate 2000 bps, drop rate 0000 bps
Match: ip rtp 2000 3000
QoS Set                    see note 2
 dscp af41
Class-map: class-default (match-any)     see note 3
  0 packets, 0 bytes 5 minute offered rate 0000 bps, drop rate 0000 bps
 Match: any
Footnotes
note 1
Statistics for the class match
note 2
Packet matching section
note 3
Class-Default statistics section
you can configure the 'QoS Packet Matching Statistics: per ACE' feature', this will also potentially increase CPU utilization though:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_mqc/configuration/xe-3s/qos-mqc-xe-3s-book/qos-match.pdf
