Please find IOS version for IP SEC service
rapeepat.s
Because want the Router 2811 support for IPsec. find the version of the Support Service as well.
Something of concern
- Memory requirements or other.
- License Base (eg IP Base image installed before the image is IP Service, will the system work?).
Philip D'Ath
IPSec will work fine with the base memory.
With the 2800 you have a specific image for each feature set, and you can move from one image directly to another (after a reboot).  You do need to buy the licences from Cisco for the feature set you are using.
The 2811 is pretty old now.  I doubt Cisco sell licences for these routers any more.
http://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/eol_c51-631228.html
You should consider moving to something modern, like a Cisco 4000 series.  A 4331 might be a good fit if you are using a 2811 now.
http://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/models-comparison.html
Joseph W. Doherty
On the 2811, IPSec "stuff" was generally included in crypto images ("k9" in image name).  I don't recall there being a separate feature license, although you did need to be approved to download a crypto image.
In other words, I recall, for a 2811, there's a non-crypto IPBase and IPServices images and crypto IPBase and IPServices images.
Depending on what you actually want to do with IPSec, besides having the crypto image, you might need a particular feature image too.
