DSL modem connection to Cisco 2811 Router?
nante9_cisco05
Can I ask you about configuration of the Cisco router?I have a PLDT DSL modem connected to a LInksys DSL Router.This is working properly and can share internet to all workstations.
We purchased Cisco 2811 Router which has only 2 FastEthernet adapter.Is it possible to share internet thru Cisco Router only connected to DSL modem?
I tried this configuration---DSL modem -->Linksys DSL Router--> Cisco 2811 Router but it didnt work.
Here are the IP address that I used..
DSL modem --static IP from PLDT
Linksys DSL router :192.168.1.1
FastEthernet0/0 :192.168.1.2
FastEthernet0/1 :192.168.1.3
Can u suggest what im going to do or the setup that im going to use?
Thank you very much.
m.sir
Level 7
Level 7
This scenario should work without problems..
But I see you are using ip address from same rage on both FastEthernets - 192.168.1.x.. Its any reason for this?? If yes you must turn on bridging on router. If not select some different transport network between Linksys and 2811
Let we say
Linksys DSL router :192.168.10.1
FastEthernet0/0 :192.168.10.2
I suppose FastEthernet0/1 is inside netwrok so it could be same - 192.168.1.3
Dont forget configure static route on 2811 with command
router(config)>ip route 0.0.0.0 0.0.0.0 192.168.10.1
M.
Hope that helps, rate if it does
jheckart
Level 3
Level 3
I would suggest removing the Linksys DSL router from the picture.
You will want to set the DSL modem in bridge mode, which will allow the 2811 to connect directly to the modem and perform the authentication tasks as well as get the public IP given from the ISP.
You'll want to be sure that you have the PPPoE information from the ISP, as well as whether they use PAP or CHAP. Most of the time, you'll run into PAP.
You'll create a dialer interface on the 2811, which you'll configure to do the PPPoE setup through the modem.
This link is for an 870 ISR, but will apply to the 2811 for the dialer interface setup.
http://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_guide_chapter09186a008045d278.html
