DTE/DCE DB60 Serial Crossover cables?
Jemhardt1
So I'm studying for my CCNA exam. I have a home lab with
2 Cisco 2514
1 Cisco 2611
1 Cisco Catalyst 2900
I can configure the Ethernet ports to work with eachother perfectly, but feel that I need to practice other technologies like Frame-realy.
I am having trouble getting my serial crossover cable to work when i connect the two 2514's together using my DTE/DCE serial crossover cable.
I tried setting the DCE end to clockrate of 5600 but the routers still say "is administratively down, Line Protocol down"
Any ideas/suggestions? I'm sure there is probably an easy solution, but i have been having a difficult time understanding what is missing.
mohammedmahmoud
Level 11
Level 11
Please go under the interface and unshut it;
interface serial 0/0
no shut
And please feel free to practice these:
HDLC Back-to-Back Connections
http://www.cisco.com/en/US/tech/tk713/tk317/technologies_configuration_example09186a00800944ff.shtml
PPP Back-to-Back Connections
http://www.cisco.com/en/US/tech/tk713/tk507/technologies_configuration_example09186a0080094504.shtml
Back-to-Back Frame Relay
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_configuration_example09186a0080094a3b.shtml
HTH,
Mohammed Mahmoud.
paolo bevilacqua
"no shutdown".
Okay, so that was a stupid question. Thanks for the links and the quick response!
Jemhardt1 do rate all the post accordingly. Thanks EM
