hello,
We have to N5K with N2K fex's. We are dual homing the fexs to the N5Ks setting up VPC between the two N5Ks and the each fex. Is it normal to see every interface on each FEX as part of a VPC?
See output below:
RchA02NccSfNx01(config-if)# sho vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 1
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : primary
Number of vPCs configured : 133
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Disabled
vPC Peer-link status
id Port Status Active vlans
1 Po1 up 1-2,9,17,197
vPC status
id Port Status Consistency Reason Active vlans
101 Po101 up success success -
102 Po102 up success success -
103 Po103 up success success -
104 Po104 up success success -
105 Po105 down* Not Consistency Check Not -
Applicable Performed
102400 Eth101/1/1 down* Not Consistency Check Not - <-----------We did not create a vpc 102400. Is this normal for a dual home configuration?
102401 Eth101/1/2 down* Not Consistency Check Not -
102402 Eth101/1/3 down* Not Consistency Check Not -
102403 Eth101/1/4 down* Not Consistency Check Not -
102404 Eth101/1/5 down* Not Consistency Check Not -
102405 Eth101/1/6 down* Not Consistency Check Not -
