Dual Internet connection on a Cisco 2900
olufemi.bakare
Beginner
Beginner
I have 2 locations in Nigeria, Lagos and abuja. I wan to share implement 2 internet connections on the 2 cisco routers, one per location.  How do i go about it?
Below is the config of the 1st router in location 1:
Building configuration...
Current configuration : 8814 bytes
version 15.1
hostname r_boyle
boot-start-marker
boot-end-marker
enable secret 5 $1$x8Ca$zIFk5rmcw4l7117SvgsRz.
enable password networkadmin
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone GMT 1 0
no ipv6 cef
ip source-route
ip cef
no ip dhcp use vrf connected
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.13.1 192.168.13.140
ip dhcp excluded-address 192.168.13.182
ip dhcp excluded-address 192.168.13.189
ip dhcp excluded-address 192.168.13.191
ip dhcp excluded-address 192.168.13.176
ip dhcp excluded-address 192.168.13.161
ip dhcp excluded-address 192.168.13.37
ip dhcp excluded-address 192.168.13.183
ip dhcp pool Boyle
network 192.168.13.0 255.255.255.0
default-router 192.168.13.1
dns-server 62.173.32.89 62.173.34.222
domain-name resort.local
lease 3
ip dhcp pool mainserver
host 192.168.13.23 255.255.255.0
license udi pid CISCO2911/K9 sn FTX1613ALQG
class-map match-any SOCIAL_NET
match protocol http host "www.facebook.com"
match protocol http host "facebook.com"
match protocol http host "gmail.com"
match protocol http host "yahoo.com"
policy-map DROP_SOCIAL_NET
class SOCIAL_NET
  drop
interface Loopback1
ip address 62.173.38.206 255.255.255.255
interface Loopback2
ip address 10.163.106.152 255.255.255.255
interface Tunnel0
description to fie
ip address 172.17.60.1 255.255.255.252
ip nat inside
ip virtual-reassembly in
tunnel source 10.163.106.152
tunnel destination 192.168.163.123
interface Tunnel2
description tunnel to headoffice
ip address 172.17.12.1 255.255.255.252
tunnel destination 192.168.164.123
interface Tunnel8
description tunnel to abuja
ip address 172.18.11.2 255.255.255.252
ip nat inside
tunnel destination 10.163.170.110
interface Tunnel9
description Tunnel to Aluminium
ip address 172.19.11.2 255.255.255.252
ip nat inside
tunnel destination 192.168.163.166
interface Tunnel11
description tunnel to ikeja
ip address 172.20.13.2 255.255.255.252
ip nat inside
tunnel destination 192.168.164.242
interface Tunnel12
description tunnel to lekki
ip address 172.20.14.2 255.255.255.252
ip nat inside
tunnel destination 192.168.164.236
interface Tunnel16
description Tunnel to Garki
ip address 172.12.13.2 255.255.255.252
ip nat inside
tunnel destination 192.168.180.94
interface Tunnel17
description Tunnel to PH
ip address 172.28.12.1 255.255.255.252
ip nat inside
interface Tunnel77
description Tunnel to PHh
ip address 172.17.80.2 255.255.255.252
ip nat inside
tunnel destination 10.60.19.98
interface Tunnel78
description Tunnel to wimax_abj
ip address 172.17.46.2 255.255.255.252
ip nat inside
tunnel destination 10.60.17.110
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description WAN interface
ip address 172.16.64.180 255.255.255.248
no ip proxy-arp
ip nat outside
load-interval 30
duplex auto
speed auto
interface GigabitEthernet0/1
description LAN interface
ip address 192.168.13.1 255.255.0.0
ip nat inside
no ip route-cache
duplex auto
speed auto
service-policy output DROP_SOCIAL_NET
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
router eigrp 25
network 10.0.0.0
network 172.16.0.0
network 192.168.1.0
network 192.168.15.0
network 192.168.18.0
network 192.168.19.0
network 192.168.24.0
router rip
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 8 interface Loopback1 overload
ip nat inside source static 192.168.13.37 62.173.38.40
ip route 0.0.0.0 0.0.0.0 172.16.64.177
ip route 10.163.0.0 255.255.0.0 10.163.106.1
ip route 10.163.0.0 255.255.0.0 10.60.18.137
ip route 10.163.106.0 255.255.255.0 10.163.192.1
ip route 10.163.106.0 255.255.255.0 10.60.18.137
ip route 10.163.106.0 255.255.255.0 10.163.170.1
ip route 10.163.106.0 255.255.255.0 10.60.17.109
ip route 10.163.106.0 255.255.255.0 10.60.19.97
ip route 62.173.38.40 255.255.255.255 GigabitEthernet0/0
ip route 62.173.38.41 255.255.255.255 GigabitEthernet0/0
ip route 62.173.38.206 255.255.255.255 GigabitEthernet0/1
ip route 172.16.3.0 255.255.255.0 10.163.106.1
ip route 172.16.6.0 255.255.255.0 10.163.106.1
ip route 172.16.19.30 255.255.255.255 10.163.106.1
ip route 192.168.10.0 255.255.255.0 172.17.60.2
ip route 192.168.11.0 255.255.255.0 172.19.11.1
ip route 192.168.12.0 255.255.255.0 172.17.12.2
ip route 192.168.14.0 255.255.255.0 172.18.11.1
ip route 192.168.16.0 255.255.255.0 172.20.13.1
ip route 192.168.17.0 255.255.255.0 172.20.14.1
ip route 192.168.19.0 255.255.255.0 172.12.13.1
ip route 192.168.20.0 255.255.255.0 172.28.12.2
ip route 192.168.21.0 255.255.255.0 172.17.2.1
ip route 192.168.21.0 255.255.255.0 172.17.2.2
ip route 192.168.22.0 255.255.255.0 172.17.80.1
ip route 192.168.23.0 255.255.255.0 172.17.46.1
ip route 192.168.27.0 255.255.255.0 172.27.17.2
ip route 192.168.101.0 255.255.255.0 172.17.20.2
ip route 192.168.163.0 255.255.255.0 10.163.106.1
ip route 192.168.163.0 255.255.255.0 172.16.64.177
ip route 192.168.163.0 255.255.255.255 172.16.64.177
ip route 192.168.164.0 255.255.255.0 10.163.106.1
ip route 192.168.164.0 255.255.255.0 172.16.64.177
ip route 192.168.170.0 255.255.255.0 10.163.106.1
ip route 192.168.180.0 255.255.255.0 10.163.106.1
access-list 8 deny   192.168.13.37
access-list 8 permit 192.168.13.0 0.0.0.255
access-list 8 permit 192.168.18.0 0.0.0.255
access-list 8 permit 192.168.19.0 0.0.0.255
access-list 8 permit 192.168.20.0 0.0.0.255
access-list 8 permit 192.168.21.0 0.0.0.255
access-list 8 permit 192.168.17.0 0.0.0.255
access-list 8 permit 192.168.15.0 0.0.0.255
access-list 8 permit 192.168.14.0 0.0.0.255
access-list 8 permit 192.168.11.0 0.0.0.255
access-list 8 permit 192.168.10.0 0.0.0.255
access-list 8 permit 192.168.23.0 0.0.0.255
access-list 8 permit 192.168.22.0 0.0.0.255
access-list 8 permit 192.168.16.0 0.0.0.255
access-list 8 permit 192.168.24.0 0.0.0.255
access-list 101 permit gre host 10.163.106.152 host 192.168.163.123
access-list 102 permit gre host 10.163.106.152 host 192.168.164.123
access-list 104 permit gre host 10.163.106.152 host 192.168.163.166
access-list 109 permit gre host 10.163.106.152 host 10.163.170.110
access-list 120 permit gre host 10.163.106.152 host 172.16.3.66
access-list 121 permit gre host 10.163.106.152 host 192.168.164.242
access-list 122 permit gre host 10.163.106.152 host 192.168.164.236
access-list 123 permit gre host 10.163.106.152 host 172.16.19.30
access-list 124 permit gre host 10.163.106.152 host 192.168.180.94
access-list 125 permit gre host 10.163.106.152 host 192.168.170.23
access-list 139 permit gre host 172.16.64.177 host 10.163.170.110
access-list 140 permit gre host 172.16.64.177 host 172.16.3.66
access-list 141 permit gre host 172.16.64.177 host 192.168.163.123
access-list 142 permit gre host 172.16.64.177 host 192.168.164.123
access-list 144 permit gre host 172.16.64.177 host 192.168.163.166
access-list 151 permit gre host 172.16.64.177 host 192.168.164.242
access-list 152 permit gre host 172.16.64.177 host 192.168.164.236
access-list 153 permit gre host 172.16.64.177 host 172.16.19.30
access-list 154 permit gre host 172.16.64.177 host 192.168.180.94
access-list 155 permit gre host 172.16.64.177 host 192.168.170.23
no cdp run
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
transport input all
scheduler allocate 20000 1000
ntp logging
end
The 2nd location's router config is:
Current configuration : 1803 bytes
version 12.4
hostname resort_Wimax_GARKI
boot-start-marker
boot config flash:flash
boot-end-marker
no aaa new-model
ip cef
ip dhcp excluded-address 192.168.23.1 192.168.23.20
ip dhcp pool wimax_garki
   network 192.168.23.0 255.255.255.0
   domain-name resort.com
   dns-server 62.173.34.222 62.173.32.89
   default-router 192.168.22.1
   lease 3
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
voice-card 0
no dspfarm
interface Tunnel1
description tunnel to boyle
ip address 172.17.46.1 255.255.255.252
ip mtu 1340
ip tcp adjust-mss 1340
tunnel source FastEthernet0/0
tunnel destination 10.163.106.152
interface FastEthernet0/0
ip address 10.60.17.110 255.255.255.252
ip nat outside
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.23.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 Tunnel1
ip route 10.163.170.0 255.255.255.255 10.60.17.109
ip route 172.16.64.177 255.255.255.255 10.60.17.109
ip route 192.168.13.0 255.255.255.0 172.17.46.2
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
login local
end
I have an existing internet connection(IPNX) and a new connection(IS) to the internet that i want to integrate. On the Lagos router, i tried implementing PBR with SLA thus:
<span style="color: #993366;" mcestyle="color: #993366;">interface GigabitEthernet0/1
<span style="color: #993366;" mcestyle="color: #993366;">ip policy route-map PBR
<span style="color: #993366;" mcestyle="color: #993366;">interface GigabitEthernet0/0
<span style="color: #993366;" mcestyle="color: #993366;">description To IPNX
<span style="color: #993366;" mcestyle="color: #993366;">!
<span style="color: #993366;" mcestyle="color: #993366;">interface GigabitEthernet0/2
<span style="color: #993366;" mcestyle="color: #993366;">description To IS
<span style="color: #993366;" mcestyle="color: #993366;">ip address 197.156.206.172 255.255.255.248
<span style="color: #993366;" mcestyle="color: #993366;">ip nat outside
<span style="color: #993366;" mcestyle="color: #993366;">ip sla 1
<span style="color: #993366;" mcestyle="color: #993366;">icmp-echo 172.16.64.177
<span style="color: #993366;" mcestyle="color: #993366;">timeout 500
<span style="color: #993366;" mcestyle="color: #993366;">frequency 1
<span style="color: #993366;" mcestyle="color: #993366;">ip sla schedule 1 life forever start-time now
<span style="color: #993366;" mcestyle="color: #993366;">ip sla 2
<span style="color: #993366;" mcestyle="color: #993366;">icmp-echo 197.156.206.169
<span style="color: #993366;" mcestyle="color: #993366;">timeout 5000
<span style="color: #993366;" mcestyle="color: #993366;">frequency 5
<span style="color: #993366;" mcestyle="color: #993366;">ip sla schedule 2 life forever start-time now
<span style="color: #993366;" mcestyle="color: #993366;">track 10 ip sla 1 reachability
<span style="color: #993366;" mcestyle="color: #993366;">delay down 1 up 1
<span style="color: #993366;" mcestyle="color: #993366;">track 20 ip sla 2 reachability
<span style="color: #993366;" mcestyle="color: #993366;">ip route 0.0.0.0 0.0.0.0 172.16.64.177 track 10
<span style="color: #993366;" mcestyle="color: #993366;">ip route 0.0.0.0 0.0.0.0 197.156.206.169 track 20
<span style="color: #993366;" mcestyle="color: #993366;">access-list 10 permit 192.168.13.0 0.0.0.255
<span style="color: #993366;" mcestyle="color: #993366;">access-list 100 permit ip any any
<span style="color: #993366;" mcestyle="color: #993366;">access-list 150 permit ip any any
<span style="color: #993366;" mcestyle="color: #993366;">these ACLs will be used with PBR and NATing
<span style="color: #993366;" mcestyle="color: #993366;">route-map PBR permit 10
<span style="color: #993366;" mcestyle="color: #993366;">match ip address 100
<span style="color: #993366;" mcestyle="color: #993366;">set ip next-hop verify-availability 172.16.64.177 1 track 20
<span style="color: #993366;" mcestyle="color: #993366;">route-map PBR permit 30
<span style="color: #993366;" mcestyle="color: #993366;">match ip address 150
<span style="color: #993366;" mcestyle="color: #993366;">set ip next-hop verify-availability 197.156.206.169 2 track 10
<span style="color: #993366;" mcestyle="color: #993366;">route-map ISP2 permit 10
<span style="color: #993366;" mcestyle="color: #993366;">match interface GigabitEthernet0/2
<span style="color: #993366;" mcestyle="color: #993366;">route-map ISP1 permit 10
<span style="color: #993366;" mcestyle="color: #993366;">match interface GigabitEthernet0/0
<span style="color: #993366;" mcestyle="color: #993366;">ip nat inside source route-map ISP1 interface GigabitEthernet0/0 overload
<span style="color: #993366;" mcestyle="color: #993366;">ip nat inside source route-map ISP2 interface GigabitEthernet0/2 overload
<span style="font-size: 14pt; color: #ff0000;" mcestyle="font-size: 14pt; color: #ff0000;">pls can anyone review my config and verify for me?
26 Replies 26
rfalconer.sffcu
Participant
Participant
I think your tracking statements are backwards on your PBR route-maps.
Can you suggest how it should be? i thought i did something wrong, but can't figure out what exactly......
ip policy route-map PBR    ---- this is for policy based routing
description To IPNX
description To IS
ip nat outside
ip sla 1 (for ipnx)
timeout 500
frequency 1
ip sla 2 (for IS)
timeout 500
frequency 1
delay down 1 up 1
delay down 1 up 1
match ip address 10
match ip address 10
(pls take a look again)
So you want the IPNX link to be primary and the IS to be secondary, correct?
set ip next-hop verify-availability 172.16.64.177 1 track 20 <------ I think this should be 10
set ip next-hop verify-availability 197.156.206.169 2 track 10 <------ I think this should be 20
You'll also still need the 'ip nat inside' commands referencing the route-maps.
Have you tested this and it doesn't work?
Thank Robert. I am yet to test it. was just dry-running this for now. tried setting up gns3 for this.....but time constraint.
Maher Abdelshkour
Rising star
Rising star
If I got you right, why don't you just set a static route for each interent connection and on one of the static routes specify a greater routing value. If the first default route fails it will use the route with the next lowest value.
ip route 0.0.0.0 0.0.0.0 0.0.0.0
ip route 0.0.0.0 0.0.0.0 0.0.0.0 10
hmmmmmmmmmmm.....would this work?
yes it should. And remember that the last 0.0.0.0 is your next hop
Good Luck!
Thank you. i would try this out too....you guys are life savers.....you just saved me from bringing down a whole bank's network....
You're welcome, Olufemi.
We're happy to help
Now let me ask. would my gre tunnels also work across the new link?
Just use two GRE tunnels, one for each ISP
ehhhhhhhmmmmmm....i inherited this network. and i am new with gre tunnels. I want to ask, the public ip address for the tunnels, will i have to get them from the new isp? or i can just pick any address?
GRE allows routers to act as if they have a virtual point-to-point connection to each other. And btw, if you want to use only one GRE tunnel, this can be done as well.
Recognize Your Peers
