Dual Internet in a active passive setup.
Mike Buyarski
Level 3
Level 3
I am trying to setup a config where i can have both my wired (primary) and Cellular (backup) connection in a active/passive setup to where is the wired connection drops it will swing over to the cellular then back to wired when wired is back up.
right now what i have works to a point, it simply does NOT swing back to the wired connection when the wired connection comes back up. I of course want it on the wired as much as i can to not use to much data on the cellular data.
Notes:
cisco 892fsp IOS ver 15.6(3)M5
vlan 15 is for the cellular connection.
gig8 is the wired connection.
/////////config////////////
ip nat inside source route-map CELLNAT interface Vlan15 overload
ip nat inside source route-map WIREDNAT interface GigabitEthernet8 overload
ip route 0.0.0.0 0.0.0.0 "Wired Gateway" track 1
ip route 0.0.0.0 0.0.0.0 Vlan15 250
ip sla 1
icmp-echo 8.8.8.8 source-interface GigabitEthernet8
threshold 15
timeout 2000
frequency 3
ip sla schedule 1 life forever start-time now
route-map WIREDNAT permit 11
match ip address 102
match interface GigabitEthernet8
route-map CELLNAT permit 10
match interface Vlan15
access-list 102 permit ip "internal ip 1" any
access-list 102 permit ip "internal ip 2" any
access-list 102 permit ip "internal ip 3" any
Seb Rupik
Hi there,
From the config you have supplied you are missing a track statement. You should have:
track 1 ip sla 1 reachability
Can you supply the output of sh track and sh ip route, for each of the follow states:
ISP1 up, ISP2 up
ISP1 down, ISP2 up
ISP1 back up, ISP2 up
cheers,
Seb.
6 Replies 6
Seb Rupik
Hi there,
ISP1 up, ISP2 up
ISP1 down, ISP2 up
cheers,
Seb.
OK i did update the config, but we will not know until the main connection drops out. i will do this config to a few of them i have to maybe increase the number this is configured on.
If the track statement was missing, its inclusion should fix your problem.
Based on recent events adding that line has allowed it to work as we wanted.
Hello
ip sla 1
Possible the reason is you ip sla address your monitoring is still reachable after failure , try changing this to a more specific address to gig8 which can reach like its next-hop interface ip address
Kind Regards
Paul
I choose 8.8.8.8 since that is the one what seems to work best for us. i can't use the gateway since that most of the time is accessible during an outage. usually i can't find a further upstream from that connection IP i can use.
