Dual isp termination on asa 5508
Anand Chourasia
     I have terminated two isp on asa-5508 and want to use both link at the same time. some selected user use the isp-1 and other users with isp-2.
     I configured PBR for this but all the traffic goes through default route. Is this possible or not in asa?
     Please help me to resolve this issue.
I configured the following:
1. Interface - Inside, Outside, backup
2. Default route outside with default metric and the backup with higher metric
3. Nat Inside to outside and Inside to backup.
4. Policy for PBR
5. Route map created
6. attached to inside interface
Anand Chourasia
2 Accepted Solutions
The next hop is set to the ASAs own address. Please remove that and try again:
route-map PBR permit 10
match ip address web-outside
set ip next-hop 10.3.96.50 10.3.96.1
The config shown is one way to do it. You could also skip the second PBR block and just point your active default-route to 172.16.1.1.
6 Replies 6
These are the steps you need to follow to configure PBR. Can you show your config? Perhaps something went wrong while configuring ...
Hi Karsten Iwen,
                             Thank for reply.
This is my configuration.  The host 192.168.1.60 are able to access internet but the second host 192.168.1.50 are not able to access while all the ports are up and the next hop are reachable.
cisco# sh run
: Saved
: Serial Number: JA#######AK
: Hardware:   ASA5508, 8192 MB RAM, CPU Atom C2000 series 2000 MHz, 1 CPU (8 cores)
ASA Version 9.5(1)
hostname cisco
enable password 2KFQnbNIdI.2KYOU encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet1/1
 nameif outside
 security-level 0
 ip address 10.3.96.50 255.255.224.0
interface GigabitEthernet1/2
 nameif backup
 security-level 0
 ip address 172.16.1.10 255.255.255.0
interface GigabitEthernet1/3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/5
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/6
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/7
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/8
 nameif inside
 security-level 100
 policy-route route-map PBR
interface Management1/1
 management-only
 no nameif
 no security-level
 no ip address
ftp mode passive
object network obj_any
 subnet 0.0.0.0 0.0.0.0
object network obj_backup
access-list sfr extended permit ip any any
access-list web-outside extended permit ip host 192.168.1.50 any
access-list web-backup extended permit ip host 192.168.1.60 any
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu backup 1500
mtu inside 1500
no failover
no monitor-interface service-module
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
 nat (inside,outside) dynamic interface
 nat (inside,backup) dynamic interface
route-map PBR permit 20
 match ip address web-backup
 set ip next-hop 172.16.1.1
route outside 0.0.0.0 0.0.0.0 10.3.96.1 1
route backup 0.0.0.0 0.0.0.0 172.16.1.1 2
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 backup
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
service sw-reset-button
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpoint ASDM_Launcher_Access_TrustPoint_0
 enrollment self
 fqdn none
 subject-name CN=192.168.1.1,CN=cisco
 keypair ASDM_LAUNCHER
 crl configure
crypto ca trustpool policy
crypto ca certificate chain ASDM_Launcher_Access_TrustPoint_0
 certificate b7167c58
    308202c8 308201b0 a0030201 020204b7 167c5830 0d06092a 864886f7 0d010105
    05003026 310e300c 06035504 03130563 6973636f 31143012 06035504 03130b31
    002db1a6 7bbbd943 da32e2b5 8db39bd1 71bae438 cae1b9ad 925ef01f 32a974bc
    2fab2758 e58d3904 32181fb2 2ac2bc70 5cdd6d1b f906637f 0a73e81d be4e710f
    789872d3 090056f0 ec45b495
  quit
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
no ssh stricthostkeycheck
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl trust-point ASDM_Launcher_Access_TrustPoint_0 inside
ssl trust-point ASDM_Launcher_Access_TrustPoint_0 inside vpnlb-ip
dynamic-access-policy-record DfltAccessPolicy
username cisco password 3USUcOPFUiMCO4Jk encrypted privilege 15
class-map sfr
 match access-list sfr
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
  inspect icmp error
 class sfr
  sfr fail-open
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:283196bf1468dcc0a30be87d4276d3ce
: end
cisco#
Anand Chourasia
Hi Karsten Iwen,
                            Thanks a lot It works now.
                 And one more question I have, If I want to pass my web traffic through Outside ISP (10.3.96.1) and other traffic through the Backup ISP (172.16.1.1) then will the following change works fine ?
access-list web extended permit tcp any any eq www
access-list web extended permit tcp any any eq https
access-list other-traffic extended permit ip any any
 set ip next-hop 10.3.96.1
 match ip address other-traffic
or any other command required?
   Thanks a lot. It works
Anand Chourasia
