06-19-2025 10:53 AM - edited 06-19-2025 09:42 PM
This is how my tipo will look end of the day.
eBGP peer Edge <---> ISP
eBGP peer between Edge < --- > Border-Leaf (I am using 65355 to peer eBGP with Edge)
Inside EVPN/VXLAN fabric I have BGP 65001.
I am Planning to do following config for stumble guys mod:
[Edge]
router bgp 3500
log-neighbor-changes
neighbor 1.1.1.1
remote-as 1500
description ** eBGP peer with ISP-1 **
address-family ipv4 unicast
send-community
send-community extended
neighbor 192.168.1.1
remote-as 65535
send-community
send-community extended[Border-Leaf]
router bgp 65001
router-id 10.254.1.2
template peer VXLAN_SPINE
remote-as 65001
update-source loopback0
address-family l2vpn evpn
send-community
neighbor 10.254.0.1
inherit peer VXLAN_SPINE
description ** iBGP Peer to Spine-1 **
no shutdown
neighbor 10.254.0.2
description ** iBGP Peer to Spine-2 **
no shutdown
vrf CUST
redistribute static route-map RTBH
aggregate-address XX.XX.XX.0/23 summary-only
aggregate-address XX.XX.XX.0/24 summary-only
neighbor 192.168.1.2
description ** eBGP Peer to Edge1 **
remote-as 3500
local-as 65535
send-community
send-community extendedQuestion:
Q1. Both ISP-1 and ISP-2 sending BGP default routes (instead of full BGP). Assuming Edge will forward that default route to my EVPN fabric, right?
Q2.Are there any issue using 65535 AS between br-leaf and edge router?
Q3. Where do I apply local-preference or AS_PATH prepend to do IP shift to ISP-1 to ISP-2 or ISP-2 to ISP-1?
06-19-2025 11:50 AM
Hello @fahadadi
Q1: Yes, the Edge redistributes or advertises that default route to its eBGP peer — in this case, the boder leaf (AS 65535). The border Leaf accept and install that route in the VRF routing table and can then redistribute it into iBGP if needed (to the evpn fabric...).
Q2: you could not use a private ASN from the range 64512–65534 instead ?
Q3: if you want to prefer one ISP over another use local-preference in inbound on the Edge.
If you want to influence how traffic from outside comes back to you, so use AS_path prepend outbound from Edge to ISP.
10-07-2025 03:44 AM
Ans 1: You will need to add default-information originate to the inward-facing peer configs.
Ans 2: Not as long as you're not using it somewhere else.
Ans 3: It depends. You can apply both on the edge routers if you want it t apply to all your VRFs. Otherwise you would put it in the VRF configuration. Another consideration is if you would need to programmatically change those parameters.
