Dual ISP
Network Pro
Consider I have this scenario
ISP1          ISP2
  |___rtr____|
I would like to use ISP1 as primary and ISP2 as secondary. So i thought of using two static routes with higher metric. I also thought about using ip sla. How do i go about about using ip sla with the above scenario. this traffic is tunnelled traffic (Dmvpn) so no outside traffic to internet so need of nat
Mark Malone
Hey use ip sla with tracking and track a route upstream in the internet with ISP1 , when that route is no longer reachable it will fail to 2nd ISP
quick example with config in this link
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/813-cisco-router-ipsla-basic.html
another option is use both ISP links at same time and allow cef to load balance rather than keeping 1 link redundent
Thanks Mark. I am using DMVPN so no nat needed (as all traffic is pushed through DMVPN) - for ISP 1 I have a tunnel interface 1 with source interface as GI0/1 (ISP1) - Will i be able to apply a second souce interface as Gi0/2 (ISP2) under same tunnel interface 1 ? I suspect not.
if I create a second tunnel (Tunnel2) and set ip sla, will the second tunnel be only formed if IP Sla fails ?
hey im pretty sure from what i remember only 1 source per physical interface
the 2nd tunnel should form with or without ip sla
the ip sla is just a monitoring function and working with tracking will just redirect traffic to the 2nd ISP link when a failure occurs , the tunnels should have no dependency on ip sla to form
