vpls: ve id and site id
UP82
In VPLS are VEID and SITE ID the same things?
The docs about VPLS are so confusing (to me)
thanks a lot
Paolo
I could not find any specific document to differentiate VE ID from site ID. I believe cisco uses VE ID while others use VE ID or site ID or customer ID.
As an example, JUNOS use Site-id in VPLS configuration.
Please check the link below.
http://www.juniper.net/documentation/en_US/junos12.1/topics/concept/vpls-label-blocks-overview.html
"The VPLS edge (VE) ID can be a unique VE ID, site ID, or customer edge (CE) ID"
This is a VPLS sample configuration In JUNOS. AS you see, site-id is used instead of VE-ID
interface xe-1/3/0.1;
route-distinguisher 10.255.0.11:2;
vrf-target target:65100:2;
protocols {
    vpls {
        site-range 20;
        no-tunnel-services;
        site DC2-VPLS {
            site-identifier 2;
            multi-homing;
            site-preference primary;
Hope it helps,
Masoud
protocols {
    vpls {
        site-range 20;
        no-tunnel-services;
        site DC2-VPLS {
            site-identifier 2;
            multi-homing;
Hope it helps,
Masoud
