Dual NAT failover not working
jopetik09
Hi All,
Below is the config has done on my 881g but the dual NAT failover is not working.
I have a easy vpn over NAT (easy vpn firewall: 10.10.10.2 behind the router).
Tested like below....
1. After completed the config, I shut down the FastEthernet4, cleared the nat translations, found that nat translations are happening on to Cellular0 with error ( Incomplete ESP translations:
0 esp_conn=0x85A91FF0, hanging off nat entry 0x85A7D1D0)
But still the easy vpn is not up as I am not able to ping the remote devices.
2. If I reboot the router then the nat translations are happening with no above error and easy vpn is up and I am able to ping the remote servers.
Can someone please see the below config and suggest me what needs to be done to achive the NAT failover and easy VPN up.
interface FastEthernet4
bandwidth 2048
ip address 206.206.206.2 255.255.255.240
ip flow ingress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Cellular0
ip address negotiated
ip nat outside
encapsulation ppp
dialer in-band
dialer string gsm
dialer-group 1
async mode interactive
ppp chap hostname *************
ppp chap password ************
ppp ipcp dns request
ip route 0.0.0.0 0.0.0.0 206.206.206.4
ip route 0.0.0.0 0.0.0.0 Cellular0 10
ip nat inside source route-map nat2dsl interface FastEthernet4 overload
ip nat inside source route-map nat2cell interface Cellular0 overload
ip nat inside source static 10.10.10.2 206.206.206.3 route-map isp1static
ip nat inside source static 10.10.10.2 206.206.206.3 route-map isp2static
access-list 101 permit ip 10.10.10.0 0.0.0.255 any
route-map isp1static permit 10
match interface FastEthernet4
route-map isp2static permit 10
match interface Cellular0
route-map nat2dsl permit 10
match ip address 101
route-map nat2cell permit 10
Please see the below nat translations for your reference...
RTR#sh ip nat tra
tcp 10.166.159.196:57877 10.10.10.2:57877 62.181.139.204:443 62.181.139.204:44
tcp 10.166.159.196:57878 10.10.10.2:57878 62.181.139.204:443 62.181.139.204:44
tcp 10.166.159.196:57879 10.10.10.2:57879 62.181.139.204:443 62.181.139.204:44
Pro Inside global      Inside local       Outside local      Outside global
tcp 10.166.159.196:57880 10.10.10.2:57880 62.181.139.204:443 62.181.139.204:44
esp 10.166.159.196:0   10.10.10.2:AB411082 195.169.210.9:0 195.169.210.9:0
--- 206.206.206.3       10.10.10.2       ---                ---
RTR#sh ip nat tra
esp 206.206.206.3:0     10.10.10.2:0     195.169.210.9:0    195.169.210.9:48D54
82B
udp 206.206.206.3:161   10.10.10.2:161   196.108.184.9:17363 196.108.184.9:1736
udp 206.206.206.3:500   10.10.10.2:500   195.169.210.9:500  195.169.210.9:500
icmp 206.206.206.3:523  10.10.10.2:523   196.108.184.9:523  196.108.184.9:523
esp 206.206.206.3:0     10.10.10.2:19285A41 195.169.210.9:0 195.169.210.9:0
Thanks in advance.
Jopeti.
5 Replies 5
mrdogantr
Hi, you can try ip sla config.
ip sla 10
icmp-echo 8.8.8.8
timeout 1000
frequency 3
ip sla schedule 10 life forever start-time now
track 10 ip sla 10 reachability
ip route 8.8.8.8 255.255.255.255 interface FastEthernet4
ip route 0.0.0.0 0.0.0.0 interface FastEthernet4 track 10
ip route 0.0.0.0 0.0.0.0 interface Cellular0 20
hth
Muammer
I have already configured the IP SAL like below but still NAT failover is not working.
ip sla 1
icmp-echo 206.206.206.2 source-interface FastEthernet4
timeout 1000
threshold 2
frequency 3
ip sla schedule 1 life forever start-time now
ip route 0.0.0.0 0.0.0.0 206.206.206.2 track 1
ip route 0.0.0.0 0.0.0.0 Cellular0 250
ip route 4.4.4.4 255.255.255.255 Cellular0
Need more suggestions.
Jopeti.
Can you change lines below.
icmp-echo 8.8.8.8 source-interface FastEthernet4
hth
Muammer
Which part you want me to change?
You want me to remove below and add what you suggest? The below is the default route which I can not change with different...
OR you just want me to replace icmp-echo 206.206.206.2 source-interface FastEthernet4 with ip route 8.8.8.8 255.255.255.255 interface FastEthernet4?
Jopeti.
Hi Guru's
Can someone help me here.
Jopeti.
