DUAL NAT
Hello!
I have the following problem,
2 ISP connections.
ADSL Internet
Intranet via DHCP
Aas two connections need work,
ADSL access, WWW E-MAIL, FTP etc ...
Intranet access, specific applications, for example, allow 10.32.102.62 ip, port 1725.
Both connections are already working on my router, but in conflict.
following script
Building configuration...
Current configuration : 2295 bytes
version 12.4
hostname ODIM
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
archive
log config
  hidekeys
interface ATM0
description //// A D S L - INTERNET \\\\
no ip address
load-interval 30
no atm ilmi-keepalive
pvc 0/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
description /// INTRANET \\\
ip address dhcp
ip nat outside
load-interval 30
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface Vlan1
description /// LAN \\\
ip address 172.10.1.254 255.255.255.0
ip nat inside
load-interval 30
ip tcp adjust-mss 1452
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
load-interval 30
dialer pool 1
dialer remote-name redback
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname teste@teste
ppp chap password teste
ppp pap sent-username teste@teste password teste
ppp ipcp dns request
ppp ipcp wins request
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1 track 123
no ip http server
no ip http secure-server
ip nat inside source route-map INTRANET interface FastEthernet0 overload
ip nat inside source route-map ADSL interface Dialer1 overload
access-list 110 permit ip 172.10.1.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map ADSL permit 10
match ip address 110
match interface Dialer1
route-map INTRANET permit 10
match interface FastEthernet0
control-plane
line con 0
line aux 0
line vty 0 4
login
end
2 Accepted Solutions
lmediavilla
You want two active nats on two different isp but you want to have the same ACL for the nat, why don't you use two different acl
if one is for internet have an ACL that excludes private ip addresses and permit any at the and
and for the intranet traffic have an ACL that permits the private ip addresses and deny the rest.
INTRANET
access-list 110 permit ip any 10.0.0.0 0.255.255.255
access-list 110 permit ip any 172.16.0.0 0.15.255.255
access-list 110 permit ip any 192.168.0.0 0.0.255.255
access-list 110 deny ip any any
ADSL
access-list 111 deny ip any 10.0.0.0 0.255.255.255
access-list 111 deny ip any 172.16.0.0 0.15.255.255
access-list 111 deny ip any 192.168.0.0 0.0.255.255
access-list 111 permit ip any any
kind regards
I wonder how you can use both links as you only got 1 default route pointing out your Internet (the other one you get from DHCP has an AD of 254 and is only used as a backup route when the first one is deleted from the RIB)and furthermore you are tracking this route but we don't see any track object in the config.
If you want both links to be used as default routes then do this:
no ip route 0.0.0.0 0.0.0.0 Dialer1 track 123
ip route 0.0.0.0 0.0.0.0 dhcp
If you want specific traffic to go out one link and other type of traffic to go out other link then you'll have to use PBR on the vlan interface.
If traffic going out the Intranet is for specific IP subnet then you may use longest match feature by configuring static route with longest match going out the Intranet interface.
Alain
7 Replies 7
lmediavilla
INTRANET
ADSL
kind regards
cadet alain
if you need to route differently according to protocol/port you will have to apply a PBR policy to your inside NAT interface and use route-maps with match interface (outgoing interface) for NAT.
Alain
The two links have to work together, the detail is that each has its work on the network.
ADSL will work with all external output.
For example, typing wwww.cisco.com, my output is ADSL
Intranet, working with internal applications.
For example, typing 10.32.102.62, my output is INTRANET.
In the current scenario only one link is working. When necessary to use external output, must overthrow the intranet. As I said my scenario is to run the two links together.
Alain
Working 100%.
cadet alain, lmediavilla, thanks for the support.
Annex Script.
interface ATM0
no ip address
load-interval 30
pvc 0/35
interface BRI0
no ip address
encapsulation hdlc
shutdown
ip address 10.48.50.214 255.255.255.0
ip nat outside
load-interval 30
duplex auto
speed auto
interface Vlan1
ip nat inside
ip policy route-map PBR
load-interval 30
interface Dialer1
description ** AUTENTICACAO COM  RADIUS **
ip mtu 1492
ip nat outside
encapsulation ppp
load-interval 30
dialer pool 1
dialer-group 1
ppp chap password 1234
ppp pap sent-username teste@teste password 1234
ip route 0.0.0.0 0.0.0.0 Dialer1 name ADSL
ip route 0.0.0.0 0.0.0.0 10.48.50.1 name INTRANET
no ip http server
access-list 130 remark ADSL
access-list 130 deny   ip any 10.0.0.0 0.255.255.255
access-list 130 permit ip any any
access-list 140 remark INTRANET
access-list 140 permit ip any 10.0.0.0 0.255.255.255
access-list 140 deny   ip any any
route-map PBR permit 10
match ip address 130
set interface Dialer1
route-map PBR permit 20
match ip address 140
set interface FastEthernet0
end
Failover doesn't work smoothly in my experience. If one link fails you need to clear the NAT table, else some egress traffic will have the wrong WAN IP.
You can get around this, but all connections get reset if one link fails.
track 10 interface FastEthernet0 ip routing
delay down 5 up 30
track 20 interface Dialer1 ip routing
delay down 5 up 30
event manager applet CLEAR-NAT-TABLE-DI0
event track 10 state any
action 1 cli command "enable"
action 2 cli command "clear ip nat translations *"
event manager applet CLEAR-NAT-TABLE-DI1
event track 20 state any
Cadet is right you should rotue private networks to one interface (or gateway) and public to the other. And I would use also a different NAT acl for each service, one that allows public ip addresses and deny private and the other ACL opposite
kind regards
