dual WAN cisco 1811 failover
policreditos
Hello! I have a router cisco 1811 with 2 of the WAN interface.
I have to configure the WAN connection with two different ISPs to allow failover.
My current setup is as follows:
ip route 0.0.0.0 0.0.0.0 ip_isp-router_1
ip route 0.0.0.0 0.0.0.0 ip_isp-router_2
With this setup, my LAN can connect to the Internet.
But when I disconect one of the two WAN interface to test failover, does not work.
The LAN lose access to the Internet,
Someone can help me please? or show me basic configuration? I do routing protocols
must create? The NTA will only work with a WAN connection .....
Thank you very much!
9 Replies 9
Giuseppe Larosa
Hello Surfinan,
First of all you need a public address pool from each of the ISP.
Post a filtered version of your config by removing public ip addresses (change them or hide with a X the second and third byte)
So you can get better help
This kind of configuration uses a route-map with multiple clauses to call for the address pools.
Or the two ISPs act as primary and backup and agree on routing to you in case of failure using the second ISP
Hope to help
Giuseppe
Thanks Giuseppe!
I meant NAT, no NTA, jajaj excuse me
Yes, I need to use one ISP to access to the internet and in case this ISP failure, use the second ISP automatically.
Show running-config:
interface FastEthernet0
description $ETH-WAN$
ip address 200.xxx.xxx.201 255.255.255.252
duplex auto
speed auto
interface FastEthernet1
ip address 200.xxx.xxx.217 255.255.255.0
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$
ip address 192.168.0.1 255.255.255.0
ip mask-reply
ip directed-broadcast
ip route-cache flow
ip tcp adjust-mss 1452
interface Async1
no ip address
encapsulation slip
ip route 0.0.0.0 0.0.0.0 200.xxx.xxx.1 permanent
ip route 0.0.0.0 0.0.0.0 200.xxx.xxx.202 permanent
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
no cdp run
control-plane
Try setting your routes with a higher metric
The route that you want your packets to take most:
The route as a backup
ip route 0.0.0.0 0.0.0.0 200.xxx.xxx.202 200
200 is the metric, but it's higher than your first, so the first will always be used unless it isn't responding.
John
HTH, John *** Please rate all useful posts ***
Thanks John, I'm going to do that.
But still can't access internet from the LAN
If I set NAT yes I can, but this only works with one WAN, and the second WAN doesn't work when the first fails.
I had understood you were meaning NAT, post your NAT config to get better help.
I agree you need to use a different AD (it is not a metric it is an AD but the suggestion is useful)
Are you using two address pools one from each provider or only one ?
Hope to help
Giuseppe
yes, AD, sorry :-)
I didn't see NAT enabled in your config at all.....
I don't have NAT enabled, because it works with only one WAN interface.
How I must setup a pool to configure NAT to work with two WAN connections?
Not sure, but try this:
Fa0:
ip nat out
fa1:
ip nat out
vlan1:
ip nat in
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
ip nat inside sour list 100 int fa0 over
ip nat insid sour list 100 int fa1 over
ip route 0.0.0.0 0.0.0.0 254
I don't know if this will work, but my thought is that the traffic for your "backup" nat pool won't be used unless there's traffic going out that route.
